305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Mixalis Nikolaou
    Cupcake Jul 3, 2020
  2. G1582468142694
    Cupcake Jul 3, 2020
  3. Caomhin
    Lollipop Jul 3, 2020
    Caomhin , via OnePlus 6T , Jul 3, 2020 :
    What camera version do you have?
    On my 6T am currently on the one in the screenshot below.
    Also try a GCam, see if that works for comparison.
    I currently have this one installed and it works very well.
    7.3_GCam_MJL_v4.1.1_Minilux.apk (marco, 2020-04-29, oneplus 6/6t, changelog)
    The XML are integrated, so no additional files required.
    https://www.celsoazevedo.com/files/android/google-camera/dev-marco/
  4. G1582468142694
    Cupcake Jul 3, 2020
  5. zayn_ys
    Honeycomb Jul 3, 2020
    zayn_ys , via OnePlus Community App , Jul 3, 2020 :
    Obviously you'll lose the data as you're going from BETA to Stable version. Better take a backup before you install the update.
  6. ItsRavi25
    Ice Cream Sandwich Jul 3, 2020
    Caomhin likes this.
  7. J1544168637947
    Eclair Jul 3, 2020
  8. ItsRavi25
    Caomhin and drl431 like this.
  9. rhyd1am
    Jelly Bean Jul 3, 2020
    rhyd1am , via OnePlus 6T , Jul 3, 2020 :
    Whilst it's fair enough to ask if someone knows a version that works. Expecting OnePlus to solve an issue with a modded app that you sideload yourself is ridiculous. OnePlus are responsible for the apps that they develope, not modded versions of Gcam!!
  10. FaleshC
    KitKat Jul 3, 2020
    FaleshC , Jul 3, 2020 :
    obviously, its phone manufacturers problem if my PUBG doesn't run well!!:rolleyes:
    LegolasX, drl431 and rhyd1am like this.
  11. T1531394569589
    Eclair Jul 3, 2020
  12. rhyd1am
    Caomhin and FaleshC like this.
  13. Abhishek_Singh_2
    Gingerbread Jul 3, 2020
  14. Abhishek_Singh_2
  15. mahivishakh
    Cupcake Jul 3, 2020
    mahivishakh , Jul 3, 2020 :
    Since the version 10.3.4 update, facing issues with calls on 6T. Unable to adjust the volume during call. Therefore, voice of person at other end is always at the maximum. Gets adjusted only via the Bluetooth earphones. Lack clarity in the person at other end's voice as well. Some kind of disturbance.With almost all calls. The person at the other end also facing issues some times in hearing. Also, sometimes the calls are not getting connected as well. Checked the network.
    Never used to face all these issues before the update.
    Tried turning the speaker phone on and then going back to normal call fix and all. Not Working.
    Sometimes, the double tap to wake feature acting weird as wel! Not responding.
    If any body has a solution, please do suggest. Thank you.
    V1537591019064 likes this.
  16. ItsRavi25
    Caomhin and Abhishek_Singh_2 like this.
  17. Abhishek_Singh_2
  18. akshaymorale
    Eclair Jul 3, 2020
  19. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Jul 3, 2020 :
    I think this is first issue that only you are facing . This is not software issue,maybe there are some changes in the settings.
    For voice issue at other end is mainly due to network and due to this sometime the hearing/receiving voice also increase.. CONTACT your carrier service...
    OR
    Clear the cache and storage of phone app.
    OR
    You can rollback to previous update as both 10.3.3 and 10.3.4 both are stable updates..Refer the procedure by @ironass
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    (Backup you data first)
    OR
    Do factory reset this will solve your all problems
    (Anyway you have to backup the data)
    Caomhin and Auristic like this.
  20. ItsRavi25
    Caomhin likes this.
