305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. LG18700
    Cupcake Jul 4, 2020
  2. rhyd1am
    Jelly Bean Jul 4, 2020
    drl431, Caomhin and Artemus. like this.
  3. LG18700
    Cupcake Jul 4, 2020
    rhyd1am likes this.
  4. Ankitkathait
    Cupcake Jul 4, 2020
  5. Caomhin
    Lollipop Jul 4, 2020
    Caomhin , via OnePlus 6T , Jul 4, 2020 :
    Backup your phone and do a full Erase All Data reset.
    LG18700, ItsRavi25 and drl431 like this.
  6. mischa1981
    Ice Cream Sandwich Jul 4, 2020
    mischa1981 , via OnePlus 6T , Jul 4, 2020 :
    Anybody also still facing the problem of stuttering in the newest build? I am on OxygenOS 10.3.4, already cleared the cached and still having those stuttering issues since Android 10 was released on OnePlus 6/6t series.
    Cleared the cache several times, also already did a factory reset, nothing solved this issue. In Android 9 I never faced this issue. I am having that issue since Android 10 so it must be an Android 10 problem. Also seen that other brand have the same issue with Android 10.
  7. Vikashlb
    Gingerbread Jul 4, 2020
    Vikashlb , via OnePlus 6T , Jul 4, 2020 :
    Try updating your launcher to the latest version.
  8. manideep6656
    Cupcake Jul 4, 2020
  9. Caomhin
    Am sure there will be a next update for 6 series phones. When that will be, who knows.
    Approx 2 months between stable updates so may be in a months time.
    mischa1981 and ItsRavi25 like this.
  10. sw_btn
  11. T1583928913408
    Cupcake Jul 4, 2020
    T1583928913408 , Jul 4, 2020 :
    Hello OnePlus team, i got 10.3.4 Oxygen OS update few days ago, I thought of upgrading from 10.3.3 to 10.3.4, but 15 days after when i realise that I should now upgrade, then I am no able to see any update now, automatically the update disappeared i am stuck on 10.3.3 on my OnePlus 6, kindly help me out to update from 10.3.3 to stable 10.3.4.
    y0uri likes this.
  12. mischa1981
  13. rhyd1am
    rhyd1am , via OnePlus Community App , Jul 4, 2020 :
    Here is the link for the incremental update for the OP6. You can install it manually via the local upgrade.
    https://otafsg1.h2os.com/patch/amaz..._22_OTA_045-046_patch_2005052115_8c01d97f.zip
    Caomhin and ironass like this.
  14. Vikashlb
    Caomhin likes this.
  15. Amanrae
    Honeycomb Jul 4, 2020
    Amanrae , via OnePlus 6 , Jul 4, 2020 :
    I tried to download it and it says app not installed! Can you help out
  16. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Jul 4, 2020 :
    First uninstall the launcher from settings>app amd notifications>see all apps>oneplus launcher ... uninstall...
    Then install the downloaded version (4.5.6)
    Caomhin and Amanrae like this.
  17. mischa1981
    But where from? My play store says it's the latest version. I am not very keen download it from unknown sources.
  18. ItsRavi25
    Caomhin likes this.
  19. MrNevil
    Cupcake Jul 4, 2020
    MrNevil , Jul 4, 2020 :
    Thanks for the update.
    I recently noticed that my volume slider goes up(to silent mode) but my phone stays in vibrate mode only.
    So actually there's lower most part is of normal mode and above both parts now after update work like vibrate mode only.
    Please help me fix this.
    Thanks in advance!
  20. skawasthi89
    Cupcake Jul 4, 2020
    skawasthi89 , Jul 4, 2020 :
    Hi, I have recently upgraded my phone to 10.3.4 and I have started facing issues with sound of phone. The in-call volume through phone and other messaging app went very low. The sound is so low that I have to now use the phone on speaker or with other headphones only for calls. The sound on speaker has also went little low. I did hard reset my phone as well but it is still same. It was working perfectly fine before update.
