305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. ItsRavi25
    Jelly Bean Jul 13, 2020
    ItsRavi25 , via OnePlus 6T , Jul 13, 2020 :
    As per the updated source the Android 11(OnePlus) will may be released in year end or first quater of 2021.
    For the issue tty to connect to OnePlus support.
    https://forums.oneplus.com/feedback
    Caoimhín likes this.
  2. ItsRavi25
    You're wrong...For OnePlus 6 series the update schedule is 1 update in every 1 or 2 months......
    If you want the really fast security updates jump to custom os....you will receive the updates in evey week and every month.
  3. ItsRavi25
  4. T1594608601438
    Cupcake Jul 13, 2020
  5. Koushik87
    Gingerbread Jul 13, 2020
    Koushik87 , via OnePlus 6T , Jul 13, 2020 :
    Probably a soft brick. Try getting into stock recovery by power + volume up and try clearing cache. If it doesn't work you might have use the msm tool to get back your phone to life. Disclaimer: Doing so you ll loose all your data and apps.
  6. Koushik87
    Koushik87
    Probably a soft brick. Try getting into stock recovery by power + volume up and try clearing cache. If it doesn't work you might have use the msm tool to get back your phone to life. Disclaimer: Doing so you ll loose all your data and apps.​
    BeingIncog
    Hello, so 6T isn't booting up, just stuck on boot animation, any help? Just wanted to recover data from it by any means... TIA.​
    You can find lot of articles in XDA forum on using MSM tool.
  7. rhyd1am
    KitKat Jul 13, 2020
    rhyd1am , via OnePlus 6T , Jul 13, 2020 :
    The last update for the 6 series was at the end of May. OnePlus has an update schedule of bi-monthly updates for our devices (which include security updates). Therefore, they are not overdue with any updates for the 6 series.
  8. ItsRavi25
    I think there no way to reinstall.....
    If you reinstall the whole software you will get epic game (epic game launcher)..
    Anyway you can directly download the fortnite from playstore.
  9. F_Disha_Dandona_qRvl
    F_Disha_Dandona_qRvl , Jul 13, 2020 :
    Hi, most of the one plus 6T devices have a screen record option that got rolled out, mine does not have or am i missing something? i checked everywhere... can someone please help me?
  10. Ján Hirner
    Honeycomb Jul 13, 2020
    Ján Hirner , Jul 13, 2020 :
    Where is the screen recorder on the OnePlus 6t?
    OnePlus
    1. You may need to add the Screen Recorder option to the Quick Settings menu. ...
    2. Simply tap the Screen Recorder toggle to get started.
    3. Once the screen recording options pop up, you can tap on the red record button to begin recording your screen.
    4. The gear icon opens the screen recording settings.
    edited/ If you have none, try download and install oxygen launcher - last one is 4.5.7, or try install screen recorder from apkmirror (latest working is 2.4.0 - on my oneplus 6...)
  11. Srínívas Sñ
    Srínívas Sñ , via OnePlus 6 , Jul 13, 2020 :
    Open panel and click panels edit option is there u want and move it to top side. Or open settings and search screen recorder.
  12. F_Disha_Dandona_qRvl
  13. DS_chakri
    Froyo Jul 13, 2020
    DS_chakri , via OnePlus 6 , Jul 13, 2020 :
    thank You [e]1f60a[/e] bro for sharing this information....it was helpful...
    ItsRavi25 likes this.
  14. RijulaMBanerjee
    Donut Jul 13, 2020
    RijulaMBanerjee , via OnePlus 6T , Jul 13, 2020 :
    I am on 10.3.4. The battery issues started after updating. I already optimised my most used apps but will try as described. Thanks
    V1537591019064 likes this.
  15. U1572862553509
  16. Ján Hirner
  17. U1572862553509
  18. Ján Hirner
  19. Ganesh Uluwar
  20. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 13, 2020
    Caomhin , via OnePlus 6T , Jul 13, 2020 :
    You only have to check today's posts over the previous page or 2 and you will see the issues, the suggestions to fix the issues you have.
    Literally over the previous 2 pages and over about 20 posts from where you posted. All readable. 🙄[e]1f440[/e]
    Amanrae, rhyd1am and ItsRavi25 like this.
