305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. rhyd1am
    KitKat Jul 18, 2020
    rhyd1am , via OnePlus Community App , Jul 18, 2020 :
    ankitshah_1290
    How to rollback to 10.3.2 and did you loose data while rollback ?​
    I've answered you 3 times over the last couple of days regarding how you can rollback!
    ONE LAST TIME!
    All instructions, links and downloads to rollback to previous builds can be found in the link below
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    Rolling back to previous versions WILL require wiping your device. Therefore you should backup any important data first.
    Auristic, ironass, kjjm and 2 others like this.
  2. mohal
    Ice Cream Sandwich Jul 18, 2020
    mohal , via OnePlus 6T , Jul 18, 2020 :
    @Abdul B. This is not good OnePlus. You are really frustrating customers. Making new phones day by day is not right thing to do. I m OnePlus 6t customer and there are lot of people like me who bought this costly device. But you are forgetting this and only concentrate new series. Some says OnePlus has lack of developers but lot of devices (like samsung) look at you 6, 6t, 6t McLaren, 7, 7pro, 7t, 7t pro, may be McLaren also, 8, 8 pro and now nord. Made 9 devices in 2 years. So plz stop doing this and take care of old series instead of stupid new things. Hope OnePlus understand what i means.
    V1537591019064 and AGROK like this.
  3. rhyd1am
    KitKat Jul 18, 2020
    rhyd1am , via OnePlus 6T , Jul 18, 2020 :
    OnePlus 6 (May 2018)
    OnePlus 6t (Nov 2018)
    OnePlus 7 (May 2019)
    OnePlus 7 pro (May 2019)
    OnePlus 7t and 7t pro (Sept 2019)
    OnePlus 8 and 8 pro (April 2020)
    OnePlus Nord (yet to release)
    I make that 4 devices released in a year not 9 as you claim 🤷‍♂️
    Auristic, Artemus., ironass and 3 others like this.
  4. bhagwat98
    Donut Jul 18, 2020
  5. Caomhin
    Community Hero 2020 Jul 18, 2020
  6. ItsRavi25
    Jelly Bean Jul 18, 2020
    ItsRavi25 , via OnePlus 6T , Jul 18, 2020 :
    Is this is Whatsapp app?
    If you're facing this issue in whatsapp then backup your chats and media and reinstall the whatsapp...
    There are many bugs in WhatsApp. 😶
    Caomhin and drl431 like this.
  7. drl431
    drl431 , Jul 18, 2020 :
    That's not great, but its not bad either. Battery life is all about the apps you install, the way you use them, and how your phone is set up. Also, you should avoid running down the battery to single digits, for better long-term battery health.
  8. Koushik87
    Gingerbread Jul 18, 2020
    Koushik87 , via OnePlus 6T , Jul 18, 2020 :
    This is OS configuration issue. Just need to re-install the OS package again. If you are rooted this will be straight forward dirty flash. If you are non rooted you need to downgrade to previous version and reinstall OS zip again. Check this forum previous pages you will find post by ironass to downgrade.
    drl431 likes this.
  9. mohal
    Don't calculate, i m just trying to say that look at devices coming in 2 years.. Hell..
    V1537591019064 likes this.
  10. rhyd1am
    KitKat Jul 18, 2020
    Except that is not at all what you said. You clearly stated 9 devices in one year. I was just putting the correct and non misleading information up.
    The way your post comes across is as if OnePlus has abandoned the 6 series completely, and that just simply isn't the case. They are still providing updates for the 6 series, in a timely manner in accordance with their update timelines.
    The 6 series will also be receiving Android 11, which in the case of the OnePlus 6 will be the 4th version of the OS....... Seems more than good enough on OnePlus's part of you ask me 🤷‍♂️
    Auristic, drl431, Artemus. and 2 others like this.
  11. rhyd1am
    KitKat Jul 18, 2020
    If correcting someone's misleading post sounds to you as though I'm an "FBI agent", then you are far too sensitive and easily offended!
    If the information you posted hadn't been misleading and incorrect, then I wouldn't have bothered replying to it. Simple solution in future..... Just check facts before posting.
    Anyway my intention was not to cause any offense or indeed to spend my time arguing. So I'll wish you a good day, and return to my beer [e]1f37a[/e] 🙂
    Auristic, drl431, Caomhin and 2 others like this.
  12. Ankur P
    Cupcake Jul 18, 2020
    Ankur P , Jul 18, 2020 :
    R u using the indian version of one plus 6??
  13. ItsRavi25
  14. Rocky065
    Eclair Jul 18, 2020
    Rocky065 , via OnePlus 6 , Jul 18, 2020 :
    Does anyone have solution to yellowish screen which is present after android 10 update. Right now I am using Advance -> Display P3 -> Cold.
    Amoled wide gamut option makes it to saturated.
  15. rhyd1am
    KitKat Jul 18, 2020
    Personally the calibration on android 10 has never bothered me, but seems to be mentioned by a lot of people that feel the same as you.
    As yet, I haven't seen anyone post any solution for it though, and I can't see it being changed anytime soon by Oneplus.
    Auristic, drl431 and Caomhin like this.
  16. rehannali
    Froyo Jul 18, 2020
  17. (DeXteR)
  18. Z1553239049735
    Froyo Jul 18, 2020
    Z1553239049735 , via OnePlus 6T , Jul 18, 2020 :
    The problem is the processor. Qualcomm keeps releasing two top processors every year that pushes all phone companies to follow, otherwise they will lose competition.
    This is all about money. Buyers keep buying.
    Auristic and mohal like this.
  19. pvilarinho74
    Honeycomb Jul 19, 2020
    pvilarinho74 , via OnePlus 6 , Jul 19, 2020 :
    There's no problem whatsoever, he is moaning because he wants to, I have a op6 and can't be happier with the support. No one is putting a gun on my head to buy a newer phone or an OnePlus phone for that matter. The funny thing is he's saying that he goes to Samsung and no Samsung has the same amount of updates, he cries for nothing on a public forum then he is called up and cries more calling people FBI agents and to not bother him...just lame...
    Auristic, Henkan, drl431 and 3 others like this.
