305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert May 27, 2020
    Caomhin , via OnePlus 6T , May 27, 2020 :
    Isn't this great screenshot to see, OnePlus back on track after the coronavirus delays, that every company had to deal with.
    And all updated as far as possible. Happy days. 😎😎
    Fair play.
  2. ashwinguy
    Gingerbread May 27, 2020
    Alikhan324 and Caomhin like this.
  3. Toni_Tumanoff
    Eclair May 27, 2020
    Toni_Tumanoff , May 27, 2020 :
    Hopefully bluetooth problems is fixed. Yesterday support team flashing my phone via Zoho connect but that doesn't solve bluetooth stuttering problem.
  4. Petar120
    Eclair May 27, 2020
  5. tarinimishra
    Froyo May 27, 2020
  6. GauravaRai
    Honeycomb May 27, 2020
    AZGARDS likes this.
  7. twlock2425
    Donut May 27, 2020
    twlock2425 , May 27, 2020 :
    I am still running the Android version from 2018 and it is not allowing me to update my phone, someone please help!!!
    W1540566609200 likes this.
  8. Caomhin
    What build is it, and what phone model?
    Xtermy likes this.
  9. twlock2425
    Donut May 27, 2020
    I have the 6t and idk where to find the build
  10. Kleb32
    Srínívas Sñ and Xtermy like this.
  11. Kleb32
    Kleb32 , via OnePlus 6T , May 27, 2020 :
    Which version of pie are you running? And ate you using OnePlus 6 or 6T?
    Xtermy likes this.
  12. Caomhin
    Go to Settings, scroll down to About Phone, you will see Oxygen OS version and Build Number
    Xtermy likes this.
  13. twlock2425
    Donut May 27, 2020
    I'm doing the oxygen updater and that's working for me, much appreciated tho
    Xtermy and Caomhin like this.
  14. Caomhin
    M1572166014907
    You need to be on Android 9.0.17 on 6T, as that's the last Pie build and contains files to allow upgrade to Android 10 versions.
    If the install fails, check the steps below.
    They will work.
    Go to the website below, download 9.0.17, manually install it following the instructions below.
    Download the software build for your device on this page. Please back up your data before flashing your device.
    https://oneplusupdates.com/device/oneplus-6t
    If you use a computer to download the file.
    Plug your phone into your computer and copy the downloaded .zip to your phone’s main root storage.
    If you’re using a Mac, you can install Android File Transfer from Appstore for this operation.
    If you download it on your phone move the file out of any folders into the Main root storage
    After the .zip file is copied to your phone, go to 'Settings' - 'system update', click the 'settings' icon on the top right corner, choose 'Local upgrade', find the .zip file and click on 'Install' to confirm.The update takes about a minute (depending upon the file size), once done reboot your device to boot into the latest Oxygen OS.
  15. twlock2425
    Donut May 27, 2020
    didn't know that, thank you
    Caomhin likes this.
  16. Godfather 1
    Jelly Bean May 27, 2020
    Caomhin likes this.
  17. yunus mohammed
    Donut May 27, 2020
    Lsksk, iamkrafi, helicopterci and 2 others like this.
  18. #38
  19. yunus mohammed
    Donut May 27, 2020
    #39
    Abdul-Rahman Hameed likes this.
  20. Iam ironman
    Froyo May 27, 2020
    #40
    Meet_GrimReaper likes this.
