305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Ján Hirner
    Gingerbread Jul 31, 2020 at 8:43 AM
  2. @sivan
    Eclair Jul 31, 2020 at 9:09 AM
  3. @chandu
    Eclair Jul 31, 2020 at 9:31 AM
  4. Caomhin
    Lollipop Jul 31, 2020 at 9:40 AM
  5. dine5h_k
    Cupcake Jul 31, 2020 at 10:07 AM
    dine5h_k , via OnePlus 6T , Jul 31, 2020 at 10:07 AM :
    Thank you so much it helped me but only for 2 days.
    Again it's happening battery is draining please help
  6. Caomhin
    Lollipop Jul 31, 2020 at 10:19 AM
    Caomhin , via OnePlus 6T , Jul 31, 2020 at 10:19 AM :
    Check post above yours, new update released and there are alternative ways to get it. See if it improves the phone.
    dine5h_k likes this.
  7. Ericb3800
    Cupcake Jul 31, 2020 at 10:55 PM
    Ericb3800 , Jul 31, 2020 at 10:55 PM :
  8. Ericb3800
    Cupcake Jul 31, 2020 at 10:56 PM
    Ericb3800 , Jul 31, 2020 at 10:56 PM :
    Been there done that, cleared cache. Bought new cable
    It's obvious Android 10 is having this issue across the board. Hoping 10.3.5 does it or I'm going back to 9
  9. drl431
    Marshmallow Jul 31, 2020 at 11:04 PM
    drl431 , Jul 31, 2020 at 11:04 PM :
    Check and clean the usb-c port on the phone more carefully, as the next step would be a visit to a service center.
    ItsRavi25 and Caomhin like this.
  10. Koushik87
    Gingerbread Aug 1, 2020 at 6:29 AM
  11. LegolasX
    Jelly Bean Aug 1, 2020 at 6:32 AM
    LegolasX , Aug 1, 2020 at 6:32 AM :
    i don't think its available yet.
  12. ironass
    Lollipop Aug 1, 2020 at 12:05 PM
    Tee_Eee_Bee, drl431 and ItsRavi25 like this.
  13. IamYadav
    Cupcake Aug 1, 2020 at 2:51 PM
  14. Caomhin
    Lollipop Aug 1, 2020 at 2:53 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 2:53 PM :
    Update to 10.3.5, then try the following.
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Once done, use the phone for a couple of days without adding apps to check for issues with just the raw fresh OOS only.
    Only introduce previous 3rd party apps gradually over 2 weeks to see if any particular app or apps drain the battery
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    OP6T Battery and Heating Thread
    https://forums.oneplus.com/threads/unified-op6t-battery-and-heating-thread.952987/
    ironass, ItsRavi25 and drl431 like this.
  15. IamYadav
    Cupcake Aug 1, 2020 at 2:56 PM
    IamYadav , Aug 1, 2020 at 2:56 PM :
    right now I'm using 10.3.1
    I heard from friends that by regular updates phone going worst day by day and same with battery backup
  16. Caomhin
    Lollipop Aug 1, 2020 at 3:13 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 3:13 PM :
    IamYadav
    I heard from friends that by regular updates phone going worst day by day and same with battery backup​
    Update to 10.3.5, then follow the steps in the post above yours.
    My battery is phenomenal, 9+ hours SOT.
    Today, still 73% left in the tank.
    ItsRavi25 likes this.
  17. IamYadav
    Cupcake Aug 1, 2020 at 3:16 PM
  18. Caomhin
    Lollipop Aug 1, 2020 at 3:25 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 3:25 PM :
    To be honest you are on a well old 10.3.1 rom, reviews make no difference. And many bugs have been ironed out in the 4 versions since.
    Up to you if you want to give what I suggest a try.
  19. Koushik87
    Gingerbread Aug 1, 2020 at 9:41 PM
    Koushik87 , via OnePlus 6T , Aug 1, 2020 at 9:41 PM :
    Playing games like asphalt wont give you a good SOT anyway. Oneplus 6T hardware is 2 years old but it wont deny anything you run on it. But considering the modern day games your cpu and gpu would take a toll. Dont expect a extraordinary battery life, if you a game lover. But switching to latest software would help you get better security with latest security patch and support for upcoming updates.
    drl431 and Caomhin like this.
  20. Marut#you
    Cupcake Aug 1, 2020 at 11:20 PM
