305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Caomhin
    Marshmallow Aug 20, 2020
    Caomhin , via OnePlus 6T , Aug 20, 2020 :
    Report the issue directly to OnePlus Developers as a Bug report.
  2. Jatin_Jadam
    Cupcake Aug 20, 2020
  3. Q1593916362980
    Cupcake Aug 21, 2020
  4. Caomhin
    Marshmallow Aug 21, 2020
    drl431 likes this.
  5. Caomhin
    Caomhin , via OnePlus 6T , Aug 21, 2020 :
    contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    rhyd1am and Q1593916362980 like this.
  6. Q1593916362980
  7. Caomhin
    So long as you are on a Global version of OnePlus 6 series phone, and already on Android 10 then you can use the details below to upgrade to 10.3.5
    choose your model of phone in the list in the link below and download and install the Android 10.3.5 file, follow the instructions given on the OnePlus Software Support page, link below.
    https://www.oneplus.com/support/softwareupgrade
    drl431, rhyd1am and ironass like this.
  8. Q1593916362980
    Cupcake Aug 22, 2020
    Q1593916362980 , via OnePlus 6 , Aug 22, 2020 :
    Not supported file in my mobile
  9. ItsRavi25
    Ice Cream Sandwich Aug 22, 2020
    ItsRavi25 , via OnePlus 6T , Aug 22, 2020 :
    Download the file from the post above your post by @Caomhin
    The extension of file should be ( .rar)
    Backup your all data
    Copy the zip to the root of your internal storage
    Go to Settings > System > System Updates
    Tap the gear icon top right, followed by 'Local upgrade'
    Read the warning and tap confirm.😇
    Caomhin likes this.
  10. Q1593916362980
  11. ItsRavi25
    If you're on 10.3.4 then download the incremental update.
    If you're on open beta then download full OTA
    Install the update manually (updated links)
    Here is the link for incremental OTA... (10.3.5)
    ONEPLUS 6
    https://otafsg1.h2os.com/patch/amaz...gen_22_OTA_046-047_patch_2007191515_f9bd1.zip
    ONEPLUS 6T
    https://otafsg1.h2os.com/patch/amaz..._046-047_patch_2007171912_5566e9d41cbb5d6.zip
    Full OTA
    ONEPLUS 6
    https://otafsg1.h2os.com/patch/amaz...Oxygen_22_OTA_047_all_2007191515_d9e52461.zip
    Full OTA
    ONEPLUS 6T
    https://otafsg1.h2os.com/patch/amaz...TOxygen_34_OTA_047_all_2007171912_ac6dc9b.zip
    Or you can download full OTA from Oneplus site
    [e]1f449[/e][e]1f449[/e]Backup your all data [e]1f448[/e][e]1f448[/e]
    Caomhin likes this.
  12. Aaditya Naiker
    Cupcake Aug 30, 2020
  13. ItsRavi25
    Ice Cream Sandwich Aug 31, 2020
    ItsRavi25 , via OnePlus 6T , Aug 31, 2020 :
    Try this
    Goto settings > Utilities > Oneplus laboratory > Dc Dimming > Enable it ( if it's not enable) / Disable it (if it's already enable).
    Try both.
    Caomhin likes this.
  14. F_Abhijit_Kure_JDnq
    Cupcake Aug 31, 2020
    F_Abhijit_Kure_JDnq , via OnePlus 6T , Aug 31, 2020 :
    Hi Team,
    Im using oneplus 6t and recently bought one plus buds as well but my buds get disconnected automatically after certain time and i have to reconnect it manual and this happens frequently.
    I tried connecting same buds to my friends oneplus 7 and they where working fine.
    But i have one plus z wireless headphones as well but they work fine on my device.
    Could please let me know why it's just happening with one plus buds.
    Regards,
    Abhijit Kure
  15. D.Sai Suhail Baba
    Honeycomb Aug 31, 2020
    D.Sai Suhail Baba , Aug 31, 2020 :
    Check Google Play Store for OnePlus buds update because I have updated OnePlus buds version through Playstore.
    Caomhin likes this.
  16. Tee_Eee_Bee
    Tee_Eee_Bee , Aug 31, 2020 :
    Other option is to update to 10.3.5 (available via download from your region's software update page) as this has beeter support for the OnePlus buds:
    We are starting to push the incremental rollout of OxygenOS 10.3.5 for OnePlus 6 and OnePlus 6T.
    Changelog
    • System
      • Optimized RAM management
      • Newly adapted OnePlus Buds, easier to take advantage of wireless connection
      • Fixed the crash issue when browsing on Chrome
      • Fixed the black screen issue when opening logkit
      • Improved system stability and fixed general bugs
      • Updated Android Security Patch to 2020.07
      • Updated GMS package to 2020.05
    ironass and Caomhin like this.
  17. F_Abhijit_Kure_JDnq
  18. F_Abhijit_Kure_JDnq
    Auto framework update is enabled in bluetooth setting and using the updated version.
  19. D.Sai Suhail Baba
    Share screenshot of your OnePlus buds apk. I'm sharing screenshot of my updated version.
    If your buds version is same as in screenshot. The problem is in your software.
    Caomhin likes this.
  20. X1575984804625
    Cupcake Sep 24, 2020 at 4:47 AM
