305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Mrivas14
    Cupcake May 28, 2020
    Mrivas14 , May 28, 2020 :
    why it says is not safe to stored data?
  2. Mrivas14
    If I do what you just said will that erase all my data again?
  3. Artemus.
    Community Hero 2020 May 28, 2020
    Artemus. , May 28, 2020 :
    It's completely safe, I've had my 6 rooted since I got it. All it's saying is in the event you install shady mods and apps you have the chance of exposing your personal data. Nothing to worry about though if you're smart enough.
    Yes. Relocking the bootloader will wipe your data.
    drl431 and ironass like this.
  4. Mrivas14
    so leave it the way it is? right?I shouldn't worry
  5. Artemus.
    Nope! Like I said, if you're smart enough this shouldn't be an issue in the slightest.
    drl431 likes this.
  6. Mrivas14
    thank you..
    Artemus. likes this.
  7. sid2984
    Donut May 28, 2020
    sid2984 , May 28, 2020 :
    How to you downgrade from 10.3.4 to 10.3.3 can you please help with the step by step procedure as the ink you sent got me a little confused
  8. Artemus.
    Community Hero 2020 May 29, 2020
    Artemus. , May 29, 2020 :
    Why do you want to downgrade?
  9. adityarajsaha , via OnePlus 6T Thunder Purple , May 29, 2020 :
    i agreed. if OnePlus do that noone can beat them....
  10. ramkr1607
    Gingerbread May 29, 2020
  11. ramkr1607
    ramkr1607 , via OnePlus 6 , May 29, 2020 :
    you r in d wrong thread bro
  12. guywong
    Froyo May 29, 2020
    guywong , May 29, 2020 :
    I think many of us would love to have the 10.3.4 full zip file. If you will share the file, it would be much appreciated.
  13. Priyankgohil 10
    Froyo May 29, 2020
  14. Tee_Eee_Bee
    Ice Cream Sandwich May 29, 2020
    Tee_Eee_Bee , via OnePlus 6T , May 29, 2020 :
    Priyankgohil 10
    can i go from open beta 6 to stable 10.3.4 ?
    You should be able to update without losing any data, as the build date of 10.3.4 will be later than Beta 6. You will need to download the file and do a local upgrade.
    You will need to have the full update file as the incremental update won't work from a beta version to stable. Not sure if the full zip for the OP 6 has been released yet.
    As a reminder, it's always good practice to back everything up prior to moving from beta to stable, just in case.
    Artemus. and Priyankgohil 10 like this.
  15. Kunqa
    Cupcake May 29, 2020
    Kunqa , via OnePlus 6 , May 29, 2020 :
    dear OnePlus, can u please fix bug with broken rounded icon shape when accent color been changed? this bug present in all Android 10 versions.
    how to reproduce: go to settings > customization > accent color > change to any.
    then clear launcher cache or just reboot phone and u got rounded before icons became square or got border like chrome.
    all this apps from screenshot have adapted rounded icon, but it became broken after accent color setting changed.
    I already created bug report, but no any news after 3 or more month of waiting
  16. Zen_monkey
    Froyo May 29, 2020
    Zen_monkey , via OnePlus 6T , May 29, 2020 :
    That's what I thought. But look at the stable update release of 7 notes. it is their in XDA forum, bit I don't find that release notes in community yet. I don't know what they mean. Can you explain what they mean by this? I was just wondering if same can be done with 6T.
    sid2984 likes this.
  17. deadcr9ck
    deadcr9ck , via OnePlus 6T , May 29, 2020 :
    why did not fix the problem with unexpected friezes of the entire system? This is already ongoing with several updates in a row. Does the phone just start to freeze strongly for 10-20 seconds when will this be fixed?
  18. W1535868078507
    Froyo May 29, 2020
  19. i_am_anurag
    Eclair May 29, 2020
