305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. G_n00blit_buHi
    Froyo May 29, 2020
    G_n00blit_buHi , via OnePlus 6 , May 29, 2020 :
    Cant disable it
    Caomhin likes this.
  2. Caomhin
    Marshmallow May 29, 2020
    G_n00blit_buHi likes this.
  3. G_n00blit_buHi
    Froyo May 29, 2020
    Oh ok, cool, done, many thanks, will see if it helps [e]1f44d[/e]
    Caomhin likes this.
  4. Auxqii
    Honeycomb May 30, 2020
    Auxqii , via OnePlus 6T Mirror Black , May 30, 2020 :
    Just messenger and my casual apps. The highest is like 7-9% of usage. As it has always been.
  5. Achyut230
    Eclair May 30, 2020
  6. saitejavarma22
    Froyo May 30, 2020
  7. dazzfarhan
    Cupcake May 30, 2020
  8. Rajkumar_Pallerla
    Donut May 30, 2020
    Rajkumar_Pallerla , May 30, 2020 :
    I did not get a 10.3.4 update so I downloaded and local upgraded it from XDA it is full of bugs and phone became slow can any one please tell me how to rollback to 10.3.3?
  9. rajesh9010
    Froyo May 30, 2020
    rajesh9010 , via OnePlus 6T , May 30, 2020 :
    downgrade same the way how upgraded downloading a file...... download 10.3.3 file and downgrade
  10. rajesh9010
    Froyo May 30, 2020
    even I didn't received 10.3.4 but my laucher version is 4.4.8 bro.......if it consumes higher then.....go to play store and uninstall OnePlus laucher....
  11. rajesh9010
    Froyo May 30, 2020
  12. imtiyazali.momin
  13. Priyankgohil 10
    Froyo May 30, 2020
    Priyankgohil 10 , via OnePlus 6 , May 30, 2020 :
    i install the 10.3.4 from open beta 6
    While installing it showed all data will be wiped.
    After installation was completed and phone rebooted all the data was there.
    But i cant see any pictures in gallery app and. ot even in other app for sharing the pic but it is available in storage. I tried to take new pic but still they are not showing in gallery or other app for sharing.
  14. Moni786
    Donut May 30, 2020
    Moni786 , May 30, 2020 :
    Good morning Team,
    This is my small concern looking forward to get a proper clarification.
    Since last 3 updates from one plus i am facing battery drainage issue. After full charge and normal usage of 3-4 hr my battery% is falling to 40-45% that to just by using YouTube whatsapp and Instagram not by playing games.
    I believe #ONEPLUS is not doing like IPHONE did earlier with there users. Effecting there battery by giving updates.
  15. K1557328612622
    Eclair May 30, 2020
  16. Y1576909795620
  17. Raresch
    Ice Cream Sandwich May 30, 2020
    Raresch , via OnePlus 6 Midnight Black , May 30, 2020 :
    hi,
    i have some questions:
    my launcher is at version 4 4.7 and i kinda like it; the functionality is great, even if the look not that much.
    1. still, the system update says that it will upgrade to 4.1.6. will that mean that will downgrade the launcher and then update again, or it will just stay la 4.4.7?
    2. the upgrade was made via Google play, and I don't get why do they change the launcher to an older version through a system update
    cheers.
  18. ItsRavi25
    ItsRavi25 , via OnePlus 6T , May 30, 2020 :
    it's staged roll-out as mentioned in first post.... limited number of devices will get updates initially...
    and Yes i am using 4.4.8 launcher version it is super smooth.
    you can download from apk mirror or from playstore (beta user)..
    Caomhin likes this.
  19. ItsRavi25
    As mentioned in thread ..there may be mistake while writing...After update your launcher will not be change it will be same 4.4.7
    Caomhin and Raresch like this.
