305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. DILIP9892
    Cupcake May 30, 2020
    DILIP9892 , May 30, 2020 :
    Thanks bro for reply this 10.3.4 update facing lot of issue & sot is 4.5hours max
  2. vidhina_23
    Eclair May 30, 2020
    vidhina_23 , May 30, 2020 :
    hi can you tell me what problem you've been experiencing, cause I think I might be having the same on my OP6
  3. arjunmanoj
    Gingerbread May 30, 2020
    arjunmanoj , May 30, 2020 :
    Hey guys, is it just me or the frequent disconnection of 5ghz wifi is still not fixed, why am I facing these issues even after all these updates? I've tried every setting on my phone but no help, is there some router setting to fiddle with? 2.4ghz works fine without disconnection but 5ghz doesn't, also custom roms don't have this issue, any idea or steps would be helpful. Thanks.
  4. vishalbihani
    Eclair May 30, 2020
    vishalbihani , via OnePlus 6 , May 30, 2020 :
    Look into matter of GMS where it doesn't identify all the OTP messages and group them. Also while texting, sometimes keyboard doesn't operate. I need to restart app.
  5. cozzmat
    Ice Cream Sandwich May 30, 2020
  6. tarun2111
    tarun2111 , via OnePlus 5 , May 30, 2020 :
    Hi,
    I have received update yesterday of 10.0.0 on my OnePlus 5 after that the voice recorder of the calls are not working it's records the call but the unable to hear the voice ☹️. please assist me to correct the same.
  7. Artemus.
    Nougat May 30, 2020
    Artemus. , May 30, 2020 :
    Wrooooong section.
    Caomhin and ironass like this.
  8. tarun2111
  9. Abdullashaikh
    Honeycomb May 30, 2020
    Abdullashaikh , via OnePlus 6 , May 30, 2020 :
    We all would appreciate if OnePlus changes it default messaging app to google messages app, it is far better than the one provided by OnePlus as Google apps include chat feature and oneplus's doesn't.
  10. FaleshC
    KitKat May 30, 2020
    FaleshC , May 30, 2020 :
    no happening anytime soon, OnePlus mentioned it their ideas announcement already.
    afaik you can already install Google messages from play store and set it as default messaging app. so what's the issue here?
    mayrsona, drl431, Auristic and 3 others like this.
  11. Artemus.
    Nougat May 30, 2020
    rHITkM, drl431, AtlasHun and 7 others like this.
  12. Caomhin
    Marshmallow May 30, 2020
    Caomhin , via OnePlus 6T , May 30, 2020 :
    Check the OnePlus Gallery Statement for more info.
    https://forums.oneplus.com/threads/...disappearance-problem-in-gallery-app.1164151/
    Artemus. likes this.
  13. Caomhin
    As you are on Beta, you will never get Stable over OTA, different channels. You will have to manually upgrade.
    Use either the 3rd party app Oxygen Updater from the Playstore
    Or check the link below from XDA. Links to manually install are there.
    https://www.xda-developers.com/oxyg...-6t-work-life-balance-epic-games-store-india/
    AtlasHun and Artemus. like this.
  14. rajesh9010
    Froyo May 30, 2020
    rajesh9010 , via OnePlus 6T , May 30, 2020 :
    from Hyderabad
    I did recieved 4.4.8 launcher update.....but not 10.3.4
  15. Caomhin
    Update your Oneplus Launcher from the Playstore, then Clear OnePlus Launcher App info Cache.
    Restart the phone, see if that helps.
    Artemus. and rajesh9010 like this.
  16. rajesh9010
    Froyo May 30, 2020
    sure I gonna try this now.....
    Caomhin likes this.
  17. Caomhin
    AtlasHun, Artemus. and rajesh9010 like this.
  18. Kalpesh555
  19. Caomhin
    ROLL-BACK FROM CURRENT ANDROID 10 Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    If you can, you could try a Full Factory Reset to fix the issue. Steps below to Factory Reset the phone.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Your phone will now restart and go through the Full reset cycle.
    And its always good practice to backup phone data before upgrading.
    ironass and Artemus. like this.
  20. Caomhin
    Am not sure but if you follow the info in that link I sent, it should be able to help.
    I did find this within that link.
