305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. abhijeetbamel
    Eclair May 27, 2020
    abhijeetbamel , via OnePlus 6 , May 27, 2020 :
    If your not qualified enough then don't come in other's matter.
    Don't you have any other work rather than pin pointing your nose in every other comment..
    Go get a life dude...There's life beyond replying to community comments.
    #81
  2. rhyd1am
    KitKat May 27, 2020
    rhyd1am , via OnePlus 6T , May 27, 2020 :
    Thanks for the advice. I will now take some time out, to assess my life choices, and consider ways to improve [e]1f44d[/e]
    #82
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert May 27, 2020
    Swejuggalo , via OnePlus 7 Pro , May 27, 2020 :
    Yeah. Annoying.
    The app feels more user friendly on the phone, but with a few annoyances, as long as you are not doing a more advanced post.
    The webpage version does not feel that well adapted to mobile browsers and small screens.
    So I'm forced to use both. Wonder if the app will work perfectly for everything one day... in the distant future... or something [e]1f609[/e]
    #83
    B_Wrath, Caomhin and Starcommander like this.
  4. haarland
    Cupcake May 27, 2020
    haarland , via OnePlus 6 , May 27, 2020 :
    Has bug! app now freeze when opening. Bug report in developer settings, still issues from Android security bulletin May. Trusted credentials had 2 out of date certificates.
    #84
  5. Swejuggalo
    App? There are many... Some mentioned Instagram I think. But they also had some strange sever issues apperently.
    #85
  6. eno_cepa
    Eclair May 27, 2020
    #86
  7. Miratek
    Honeycomb May 27, 2020
    #87
    vidhina_23, Santoshtheone and Caomhin like this.
  8. Kerngehirn3
    Kerngehirn3 , via OnePlus 6 , May 27, 2020 :
    Volte and vowifi are working on 10.3.3 in Germany (congstar/Telekom)
    #88
    Caomhin likes this.
  9. julez_
    Eclair May 27, 2020
    julez_ , via OnePlus 6T , May 27, 2020 :
    Not for me. I had to manually enable it with PDC.
    #89
  10. Kerngehirn3
    Yes. Thats obvious. It doesn't work any other way in Germany as far as I know.
    #90
    Caomhin likes this.
  11. GauravaRai
    GauravaRai , via OnePlus 6 , May 27, 2020 :
    can anyone tell me current version of notes app on 10.3.4 update. I uninstalled it. now when I'm installing latest version of notes app from apkmirror it doesn't sync notes uploaded on cloud.
    #91
  12. rhyd1am
    KitKat May 27, 2020
    Version 3.2.0.191127164546.59b5cb6
    #92
    suraj1595, ironass and Caomhin like this.
  13. GauravaRai
    #93
    rhyd1am likes this.
  14. Hiten.Shah
    Froyo May 27, 2020
    #94
    Caomhin likes this.
  15. julez_
    Eclair May 27, 2020
    Since Android 10 it worked with nothing to do. Up until 10.3.3, there it doesn't work.
    OnePlus is aware of this issue.
    With Android 9 you had to enable it manually in Engineering Mode, but that's it. PDC only is necessary because the messed the update up.
    #95
  16. Caomhin
    Caomhin , via OnePlus 6T , May 27, 2020 :
    Usually the new versions go to 6T first, then about a week later, they show up on the older 6 version. It's the Staged Rollout thing. So give it a little time.
    #96
  17. Caomhin
    I am sure that they would, if they knew what they were.
    #97
    Trevor.Hawkes likes this.
  18. Caomhin
    I was on Beta 6,returned to 10.3.3, battery life and everything in the phone still works great, but you will lose the additional features that Beta 6 has.
    If you don't use them, the 10.3.3 & 10.3.4 should both work great anyway. It's a personal choice.
    #98
  19. Caomhin
    If you move to Stable, you lose the Beta features
    #99
  20. Caomhin
    OnePlus 9 Series Expert Community Expert May 28, 2020
    Caomhin , via OnePlus 6T , May 28, 2020 :
    Do a full Erase/Delete All Data factory reset.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    manik_sachin likes this.
