305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Phoenix98
    Cupcake Jun 1, 2020
    Phoenix98 , via OnePlus 6T , Jun 1, 2020 :
    Ohh. Then it's cool since I have been using hotspot intensively for last few days due to frequent power cuts 😅
    Simply mentioning "Hotspot" would have helped, who would know it's for hotspot when name is mentioned as "-5". [e]1f603[/e][e]1f61c[/e]
  2. Muhammad_Kashif_bahl
    Gingerbread Jun 1, 2020
  3. H1591021860524
    Cupcake Jun 1, 2020
  4. R1543465200018
    Froyo Jun 1, 2020
    R1543465200018 , Jun 1, 2020 :
    I have doubt here. might be silly for u guys, but still wanna ask.
    Suppose I download 10.3.4 from oxygen updater. It is not rolling out to all users because some issues OnePlus might be fixing as part of 10.3.4 and release to all users as OTA update 10.3.4.
    so those who have installed earlier version, might not get the fixed version of 10.3.4... or OnePlus will not fix anything once it appears in oxygen updater.
    Please let me know how it works? thanks
  5. A1550387522048
  6. drl431
    Nougat Jun 1, 2020
    drl431 , Jun 1, 2020 :
    I would not expect different versions of OOS to have the same version number. If a problem were discovered, the release would be halted, and a new version (and number) would be released. Imagine the logistics of tracking different OOS versions with the same number.
    Artemus. and Caomhin like this.
  7. Elatchian Veeramani
    Honeycomb Jun 1, 2020
  8. Aman.Bhardwaj
  9. Nitish_Gupt
    Cupcake Jun 1, 2020
  10. R1543465200018
    Froyo Jun 1, 2020
    G_Dhanapal_mEPD likes this.
  11. Anistar22
    Donut Jun 1, 2020
  12. Caomhin
    Marshmallow Jun 1, 2020
    Caomhin , via OnePlus 6T , Jun 1, 2020 :
    It's not gone for me, works fine. Just click on where its says Expanded Screenshot in the blue background at the bottom of the shot just taken. Then when opens full screen just let it scroll automatically.
    Artemus. likes this.
  13. Caomhin
  14. MR.HUNT07
    Cupcake Jun 1, 2020
  15. Tatik
    Cupcake Jun 1, 2020
  16. Caomhin
    Tatik
    Hello how can I change from Hydrogen Os to Oxygen Os in my Oneplus 6, I try to install the latest version and it tells me that it is older ... Thanks​
    [e]26a0[/e]️You may have to do it as a downgrade. However it would be something you would be doing Entirely at your own Risk[e]26a0[/e]️
    ROLL-BACK FROM CURRENT ANDROID 10 Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    This will wipe the phone, so you will need to backup your Data.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone.
    If that doesn't work, then you might have to use the MSMDownload tool.
    Follow the instructions to use the MSMDownload Tool for Oneplus 6.
    https://www.thecustomdroid.com/oneplus-6-6t-unbrick-guide/
    Scroll down to view the Unbrick details and downloads.
    Download and use the Android version you want TO use to unbrick the phone with for OP6.
    Once you have the phone backup and running.
    Install OTA updates to get the most recent update.
    ironass and Artemus. like this.
  17. Kista_hyd
    Eclair Jun 1, 2020
  18. A1550387522048
    A1550387522048 , via OnePlus 6 , Jun 1, 2020 :
    No bugs, no crashes, any problem which destroys the frequently using apps...no crazy battery draining..what I would wish more...
    Caomhin likes this.
  19. 6T_Valeriy_Malinovskiy_
    Donut Jun 1, 2020
    6T_Valeriy_Malinovskiy_ , Jun 1, 2020 :
    What about certifying converted T mobile 6t ?
    First reports about Google pay issue are almost 6 month old. Are there chances that my converted A6013 would become fully functional again?
  20. weaselvali
    Cupcake Jun 1, 2020
    A1550387522048 likes this.
