305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. PrasadSp
    Cupcake Jun 1, 2020
  2. L1577744259743
    Cupcake Jun 1, 2020
    L1577744259743 , Jun 1, 2020 :
    When on data, phone switches automatically to an available unknown WiFi point. I then have to manually disable WiFi to get internet back. When will this finally be fixed? This bug was introduced with the Android 10 update.
  3. Artemus.
    Nougat Jun 1, 2020
    Caomhin likes this.
  4. Abhishree123
    Cupcake Jun 1, 2020
    Abhishree123 , via OnePlus 6T , Jun 1, 2020 :
    माननीय , कब तक मिलेगा हमें अपडेट ?
  5. Abhishree123
    Cupcake Jun 1, 2020
  6. L1591034080470
    Cupcake Jun 1, 2020
  7. Federico Martin
    Gingerbread Jun 1, 2020
    T1539496809178 likes this.
  8. Caomhin
    Lollipop Jun 1, 2020
    Caomhin , via OnePlus 6T , Jun 1, 2020 :
    That would be one for OnePlus Developers.
    Send it to them as feedback.
    Feedback tool
  9. Caomhin
    Reset your Bluetooth adapter, see if that helps
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    Also reset the Bluetooth devices that you are connecting to.
    Check the device user manual on how to do that.
    Then pair them again
    Batman360 likes this.
  10. Madhur89
    Cupcake Jun 1, 2020
    Madhur89 , Jun 1, 2020 :
    Agreed!!! the battery lasts 11 to 12 hrs on my one plus 6 also.
  11. T1539496809178
    T1539496809178 , Jun 1, 2020 :
    Did it fix? im having this bug still ....i have downloaded 4.4.8 from apk mirror...i didnt get it on playstore yet.....
    Federico Martin likes this.
  12. Caomhin
    If the Launcher is crashing, you will need to clear both OnePlus Launcher App info Cache and App info Storage to see if it can help.
    However this will completely reset the desktop, and you would have to setup your desktop icons and shelf again.
    If this doesn't work, then uninstall the launcher updates from the 3 dot menu in OnePlus Launcher App info. This will also reset your shelf and desktop to defaults.
  13. T1539496809178
    Caomhin
    If this doesn't work, then uninstall the launcher updates from the 3 dot menu in OnePlus Launcher App info. This will also reset your shelf and desktop to defaults.​
    have tried both...nothing works... since 10.3.2 ive been trying this....its not working...
  14. ramkr1607
    Froyo Jun 1, 2020
    ramkr1607 , via OnePlus 6 , Jun 1, 2020 :
    clear the cache after update..
  15. F1591039009323
    Cupcake Jun 1, 2020
  16. Caomhin
    Oh right, you mean on your phone, because others have reported it works fine on their phones.
    Have you reset your Network adapter.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also take out the Sim and clean it also try it in the other Sim drawer.
    Also check with JIO network provider that the network in your area is capable of the network features you are looking for in your area.
  17. F1591039009323
    Cupcake Jun 1, 2020
    F1591039009323 , Jun 1, 2020 :
    Caomhin
    Also check with JIO network provider that the network in your area is capable of the network features you are looking for in your area.​
    yes i did reset the settings and everything.
    its been two days, i have updated my phone for the latest OS version 10.3.3 released for OnePlus6, and since then I am facing a lot of issues in the network with my JIO sim card. I tried applying other networks sim cards in both the slots and its working. But my Jio sim is not working in any slot in my OnePlus6. whereas my Jio sim is working in every other phone. therefore there is some problem with the update which has been released. can you please look into this as soon as possible.
  18. Federico Martin
    Federico Martin , via OnePlus 6T , Jun 1, 2020 :
    I'm using and see if it happens again. It happens randomly and rarely sometimes two times in one day, sometimes two times in one week. I just installed from Play Store, clear only cache of launcher and reboot. Let's see what happens [e]1f44d[/e]🏻
  19. 6T_Valeriy_Malinovskiy_
    Donut Jun 1, 2020
    Caomhin likes this.
  20. Caomhin
    All users here same as yourself, contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    drl431 likes this.
