305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Q1541682856033
    Cupcake Jun 2, 2020
    Q1541682856033 , Jun 2, 2020 :
    My game play lagging so hard when I am using screen recorder after new update 10.3.3. Op can you if it.
  2. Gokul7373
    Gingerbread Jun 2, 2020
  3. ItsRavi25
    Ice Cream Sandwich Jun 2, 2020
    Caomhin likes this.
  4. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Jun 2, 2020 :
    Read first post[e]1f602[/e]
    Caomhin likes this.
  5. Q1541682856033
    Cupcake Jun 2, 2020
    Yes cause it's lagging hardly ... I can t play with screen recorder .[e]1f62d[/e][e]1f62d[/e][e]1f62d[/e]
  6. J1589530617726
    Cupcake Jun 2, 2020
    nj30@ likes this.
  7. _BlackPanther_
    Honeycomb Jun 2, 2020
    _BlackPanther_ , Jun 2, 2020 :
    Thanks for letting us know, keep waiting couple more weeks.
    Caomhin and Pepa1977 like this.
  8. Caomhin
    Lollipop Jun 2, 2020
    Caomhin , via OnePlus 6T , Jun 2, 2020 :
    10.3.4 is a higher build to Beta 6.
    You may have to downgrade to 10.3.2, or 10.3.1 then install Beta 6 Manually from there. But there was a slight complication when going through Beta builds at the time.
    As there were 6 Betas for 10 and some of them involved having Beta 2 before updating further. You may need to go right back to a previous stable 10 build .
    It would involve checking all the 10 Beta Build initial install posts for each build to get the process involved.
    Like I said previously, it is a complicated process due to the way Android 10 Beta install timelines we're were not exactly linear. Some were Incremental only updates dependent on a particular version installed before updating and others were Full install
    B]ROLL-BACK FROM CURRENT ANDROID 10 Stable TO EARLIER STOCK ANDROID 9 OR 10[/B]
    Thanks to @ironass for putting this together.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    ironass likes this.
  9. Caomhin
    Staged Random Rollout currently.
    Use either the 3rd party app Oxygen Updater from the Playstore
    https://play.google.com/store/apps/details?id=com.arjanvlek.oxygenupdater
    Or check the link below from XDA. Links to manually install are there.
    https://www.xda-developers.com/oxyg...-6t-work-life-balance-epic-games-store-india/
    ironass likes this.
  10. ravisiri2009
    Cupcake Jun 2, 2020
    ravisiri2009 , Jun 2, 2020 :
    Why are you not sending updation for oneplus 7 whereas the updation for the rest of the sets are available?
  11. Caomhin
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    ironass likes this.
  12. Caomhin
    Because this is the 6 series thread, try 7 series threads. If you use software from 6 series, you will end up with a doorstop.
    ItsRavi25 and rHITkM like this.
  13. T1539496809178
    T1539496809178 , Jun 2, 2020 :
    clearing launcher cache and rebooting has severed the bug of crashing of the launcher bug ....im just giving up now....and will try to get used to it....no option now....one plus cant fix it even after knowing about the bug and having fixed that bug in the open betas they are not able to identify and fix that same bug in the stable build....[e]1f62a[/e]
  14. T1539496809178
    Here this is the proof of it.... though i was never an open beta user.....but look at the changelogs......this issue fix never came to the stable build
  15. Caomhin
    Have you tried the other option of uninstalling the update.
    If still causing issues. Also try Backing up the phone and do a Full Factory Erase All Data reset.
    rHITkM and T1539496809178 like this.
  16. L1540695497723
    Cupcake Jun 2, 2020
  17. R1543465200018
    Froyo Jun 2, 2020
    R1543465200018 , Jun 2, 2020 :
    my 6T device battery drains very fast. I'll get another 30 mins, which means 5 hrs SOT.
    if you can see the battery graphs. I haven't played any games. Just normal stuffs we use daily.
    So 5hrs of SOT is very less if you ask me without heavy usage.
    Let me know guys how much SOT you are getting for 6T device.
    launcher : 4.4.8
    OS : 10.3.3
  18. sanjayshahaaccam
    Cupcake Jun 2, 2020
  19. Q1541682856033
    Cupcake Jun 2, 2020
    sir ... after update ..my device lagging hardly in gaming time when I run OP screen recorder...
