305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 7, 2020
    Caomhin , via OnePlus 6T , Jun 7, 2020 :
    Yup, they are a commercial product to serve up adverts to make a profit, and merely read what's already within the phone itself. Presents it in a glitzy format and even ends up draining the battery itself.
  2. souravka6
    Gingerbread Jun 7, 2020
    souravka6 , via OnePlus 6 , Jun 7, 2020 :
    how to check battery helth with out third party app?
  3. ItsRavi25
    Jelly Bean Jun 7, 2020
    ItsRavi25 , via OnePlus 6T , Jun 7, 2020 :
    For battery usage
    Settings >Battery>View detail usage
    You will get the idea which thing is consuming the battery app or system..
    Go to battery optimization click on the app which consumes more battery and select optimization (if it is Intelligent optimization)..
    Use of third party app will never give proper result..
    And do battery calibration..as mentioned in above post..
    Hope this will work for you.
    drl431, Auristic and Caoimhín like this.
  4. mr_toni_kun
    Eclair Jun 7, 2020
  5. rhyd1am , via OnePlus Community App , Jun 7, 2020 :
    It's a staged, random rollout. It goes first to a smaller group of "random" users, before going out to increasingly larger groups of users, and can take a couple of weeks to reach everyone.
    It's done this way to try to minimise the chance of any major bugs getting out there. Be patient and it'll soon reach your device 🙂
    Caoimhín and Auristic like this.
  6. Auristic
    Lollipop Jun 7, 2020
    Auristic , Jun 7, 2020 :
    Then you're not one of the "chosen ones": read Post #1 for details and if you still don't understand why read it again until you do.
    Edit: Ninjaed by @rhyd1am! ;)
    Caoimhín and rhyd1am like this.
  7. Lunjin
    Cupcake Jun 7, 2020
  8. Caomhin
    Check for the features included, which are few and go ahead an play with them. Check the first post top of the thread to find out what's included.
  9. deepakrohila81
    Donut Jun 7, 2020
  10. 4224raj
    Eclair Jun 7, 2020
  11. Cervantes
    Moderator Moderator Jun 7, 2020
    Cervantes , Jun 7, 2020 :
    Hi
    the best option is to wait for the system to notify you of the update
    Gokul7373 and drl431 like this.
  12. Shak321
    Cupcake Jun 7, 2020
    Shak321 , Jun 7, 2020 :
    i am currenly in o2 beta35 can i upgrade to 10.3.4 by local upgrade...please replyy
  13. Shak321
    Cupcake Jun 7, 2020
    i am currently in o2 beta35 can i upgrade to 10.3.4 by local upgrade please replyy?
  14. rads2312
    Honeycomb Jun 7, 2020
  15. salmanattar likes this.
  16. Koushik87
    Koushik87 , via OnePlus 6T , Jun 7, 2020 :
    Yes, but you wil loose your data on switching from beta to stable channel. Do proper backup, then only try.
  17. Auristic
    Then either you're already using the latest firmware (10.3.4) or you didn't read this thread.
    Caoimhín and ItsRavi25 like this.
  18. apbarshikar
    Cupcake Jun 7, 2020
    apbarshikar , via OnePlus 6T , Jun 7, 2020 :
    My phone goes into infinite ringing mode when I connect to Teams, Meet or Duo using Bluetooth headset. This was not the case until 10.3.2. Only option restart the phone.
