305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. S1531502170183
    Froyo Jun 7, 2020
    S1531502170183 , Jun 7, 2020 :
    not got update yet,I love my phone ....all is great software & hardware....but two things I am not happy ...first not change different font style...or second is while playing pubg most of my friend & my itself the button are permanently see on screen like screen burn issue......
  2. 27jignesh
    Cupcake Jun 7, 2020
  3. MCunha
    Gingerbread Jun 7, 2020
    MCunha , Jun 7, 2020 :
    Version 10.3.3 fixed Wi-Fi roaming to me, and 10.3.4 broke it again [e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e]
  4. Manosri007
    Donut Jun 7, 2020
    Kleb32 and avi7lanjewar like this.
  5. Ujas Thakkar1
    Cupcake Jun 7, 2020
  6. R1543465200018
    Froyo Jun 7, 2020
    R1543465200018 , via OnePlus 6T , Jun 7, 2020 :
    I'm also facing this issue in 10.3 3. now in 10.3.4 also I faced this issue. But for me it took 4-5 seconds to open settings.
    It happens sometimes, not all the time while opening settings menu.
    Yes, it is an issue. OnePlus should address this issue, because many of users facing this issue.
    avi7lanjewar likes this.
  7. dnyanesh3d
    Donut Jun 7, 2020
    dnyanesh3d , Jun 7, 2020 :
    still not received update OxygenOS 10.3.4 on my OP6T how many days it will take to see in System Update.
  8. dnyanesh3d
    Donut Jun 7, 2020
    same here not received update for OP 6T.
  9. Auristic
    Lollipop Jun 7, 2020
    Caoimhín likes this.
  10. ManuKatyal
    Cupcake Jun 7, 2020
  11. Elatchian Veeramani
    Honeycomb Jun 7, 2020
    Elatchian Veeramani , via OnePlus 6 , Jun 7, 2020 :
    I think it's because of Loading that OnePlus Red cable Menu. they should remove it
  12. UDM
    Cupcake Jun 7, 2020
    UDM , via OnePlus 6 , Jun 7, 2020 :
    I don't know what kind of distribution or staging of update OnePlus follows, if even after 15 days of announcement, you can't push it to all users...
    it's nothing but waste of time
    MarcW1 likes this.
  13. ItsRavi25
    Jelly Bean Jun 7, 2020
    ItsRavi25 , via OnePlus 6T , Jun 7, 2020 :
    It is simple to update directly using oxygen updater..as both are same...
    10.3.4 is staged roll-out..at present it is reached to few devices..it will take time to reach all devices globally.
    MCunha and Caoimhín like this.
  14. ItsRavi25
    Do the battery calibration..it will helpful for your device..
    you will get great battery backup..
    see post no #1673 by @Caomhin
  15. I1541253864383
    Cupcake Jun 7, 2020
  16. ItsRavi25
    Go to settings>Apps and notification>See all apps>Oneplus launcher
    Clear the permission and clear the data..... install new version if you're using old version.. restart your device.. problem solved 😇
    Caoimhín and drl431 like this.
  17. ItsRavi25
    It is part of Android 10...If you have good knowledge of the rom stuff goto XDA. They have mentioned about this...
  18. I1541253864383
    Cupcake Jun 7, 2020
    I1541253864383 , Jun 7, 2020 :
    I know but I want a workaround. If it is not possible I want an official explanation from Oneplus itself.
  19. ItsRavi25
    Goto game space settings ...>How to show notification>Block
    it will block your all notification while playing game
    And also untick the Notification from 3rd party calls
