305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. ItsRavi25
    Jelly Bean Jun 7, 2020
    ItsRavi25 , via OnePlus 6T , Jun 7, 2020 :
    Better to ask GOOGLE [e]1f609[/e]
    Caoimhín and mischa1981 like this.
  2. I1541253864383
    Cupcake Jun 7, 2020
  3. ItsRavi25
  4. I1541253864383
    Cupcake Jun 7, 2020
    I1541253864383 , Jun 7, 2020 :
    I have the knowledge. What I don't have is the willing and the time. I'll root my OP6 when official support ends. Till then, I demand official solutions for a real problem. Asking Google isn't one.
  5. S_Giriprasath , via OnePlus 6 Mirror Black , Jun 7, 2020 :
    As of now OnePlus has no plans to do anything about that space. Hope they'll be able to do something in Future.
  6. B_Wrath
    Nougat Jun 7, 2020
    B_Wrath , Jun 7, 2020 :
    That's the only one that will at least matter. You can ask OnePlus all you want and you'll get the same answer as we are giving you now: "Google decided it to be that way in Android 10. It will stay that way till they decide to change it."
  7. Kleb32
    Gingerbread Jun 7, 2020
    Kleb32 , via OnePlus 6T , Jun 7, 2020 :
    If I had a dollar for every times I have seen such a comment since Android 10 was rolled out I would be rich.
    13Vermasameer likes this.
  8. 13Vermasameer
    Eclair Jun 7, 2020
    13Vermasameer , via OnePlus 6T , Jun 7, 2020 :
    ONE PLUS LAUNCHER AUTOMATICALLY GETS RESET AND OPEN ANY RECENT APP. WHY IT IS HAPPENING??
    device- 6t 10.3.4
    launcher version- 4.4.2 and also new apk is not getting installed. showing error
  9. rHITkM.
    Ice Cream Sandwich Jun 7, 2020
    rHITkM. , Jun 7, 2020 :
    13Vermasameer
    device- 6t 10.3.4
    launcher version- 4.4.2 and also new apk is not getting installed. showing error​
    is it the play Store or Apkmorror you are trying to download from.
    Caoimhín likes this.
  10. 13Vermasameer
    Eclair Jun 7, 2020
    APK mirror. there is no update available in playstore.
    main issue is crashing. automatially gets reset after usage of apps. and opens last opened app
  11. Abhilash.D
    Eclair Jun 7, 2020
    Abhilash.D , via OnePlus 6 , Jun 7, 2020 :
    Usually how many days it will take to OTG to reach everyone..??
    Last update 10.3.3 received after 15days of release and now how many days.?? FYI- I know I can use apps like oxygen updater but I don't want to use...
  12. rHITkM.
    yesterday I left the beta version 4.4.8 of the launcher , after that I uninstalled the launcher updates and then updated it. I updated it again and got 4.4.8 .
    check it again it must be available.
  13. rHITkM.
    should be the same time frame 2 weeks
  14. 13Vermasameer
    Eclair Jun 7, 2020
    Yes i uninstalled. and updated to 4.4.8 . now will check if it crashes or not
    rHITkM likes this.
  15. rHITkM.
    ok.
  16. mischa1981
    mischa1981 , via OnePlus 6T , Jun 7, 2020 :
    you just don't get it, do you? "BUT I WANT!!!" doesn't work here.
    Auristic, B_Wrath and drl431 like this.
  17. vishrutjha
    Honeycomb Jun 7, 2020
    vishrutjha , via OnePlus 6 , Jun 7, 2020 :
    I recently updated to OOS 10.3.4 and am facing this weird issue.
    My screen is calibrated to AMOLED Wide Gamut and the colors are on the coldest end of the spectrum. Yet, when I long press on a certain text to select it, as long as the select options tooltip shows up, the screen colors turn warm...
    Is anyone else facing this problem? Or can anyone suggest me a solution?
    P.S. I tried to record the behavior on Screen Recorder, but it doesn't capture the change (of course 🤷🏻‍♂️)
  18. S1531502170183
    Froyo Jun 7, 2020
  19. Artemus
    Community Hero 2020 Jun 8, 2020
    Artemus , Jun 8, 2020 :
    Oxygen Updater. You're welcome.
  20. Ajay_ydv
    Gingerbread Jun 8, 2020
    Ajay_ydv , via OnePlus 6 , Jun 8, 2020 :
    Facing the issue of unbalanced output from earphones. The right earpiece is louder than left one. tried them on other devices and they were fine. Please help me.
    iamkrafi likes this.
