305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. FaleshC
    KitKat Jun 8, 2020
    FaleshC , Jun 8, 2020 :
    setting>system>accessibility>audio balance
    mayrsona, LegolasX, Caoimhín and 2 others like this.
  2. Ajay_ydv
    Gingerbread Jun 8, 2020
    Ajay_ydv , via OnePlus 6 , Jun 8, 2020 :
    Thank you for your suggestion. I am doing it but the problem with it is that I have to adjust everytime I plug and unplug the earphones because it affects the speaker output too.
  3. deepakrohila81
    Donut Jun 8, 2020
    deepakrohila81 , via OnePlus 6 , Jun 8, 2020 :
    thanx....prob...solve
  4. The_Huntsman
    Froyo Jun 8, 2020
    robin143, bakshi.arnab and _abhi46_ like this.
  5. Gulsarora
    Eclair Jun 8, 2020
    Gulsarora , Jun 8, 2020 :
    Has it been rolled back or any other issue with the update? I didn't receive the update till now.
    shetakesubhash7 likes this.
  6. sshetake
    Donut Jun 8, 2020
    bakshi.arnab likes this.
  7. Auristic
    Lollipop Jun 8, 2020
    Auristic , Jun 8, 2020 :
    What are you waiting for?
  8. Ján Hirner
    Honeycomb Jun 8, 2020
  9. sshetake
    Donut Jun 8, 2020
  10. rHITkM.
    Ice Cream Sandwich Jun 8, 2020
    rHITkM. , Jun 8, 2020 :
    no such problem on my device OP 6 10.3.4 .
    Caoimhín likes this.
  11. Trevor.Hawkes
    Trevor.Hawkes , Jun 8, 2020 :
    Here's one for the clever boys and girls.
    I'm running my 1+6 on 10.3.4.
    All is working very well.
    But, I'm being driven mad trying to explain something I have noticed recently.
    First I must say I do not have an unstable or erratic WiFi connection.
    But.
    If I look at my phone in the middle of the night my WiFi is not connected and my mobile connection icon shows 4g.
    Within a few seconds the WiFi icon turns on and the mobile connection no longer has the 4g showing.
    As I have only seen this at night I can only assume it needs a period of inactivity to kick in.
    I have no idea as to when this started happening. It could have started anytime I suppose.
    I have been turning things on and off till I'm sure I'm repeating things now.
    I'm sure the 4g symbol is a clue but I'm not seeing what that means.
    Im looking for an explanation and only a "cure" if it turns out to be a bug.
    If the answer is obvious don't worry. I've given it my best shot and failed.
    rHITkM likes this.
  12. RECON007
    Cupcake Jun 8, 2020
  13. Tee_Eee_Bee
    Tee_Eee_Bee , via OnePlus 6T , Jun 8, 2020 :
    Trevor.Hawkes
    But.
    If the answer is obvious don't worry. I've given it my best shot and failed.​
    Have a look in Settings -> Battery -> Battery Optimisation.
    Then tap on the 3 dots in the top right hand corner, then tap on Advanced Optimisation.
    If Sleep standby optimisation is enabled, then your wifi will more than likely turn off when your phone has been idle for some time. It's a battery saving trick that OnePlus use.
    Auristic, ironass, rHITkM and 2 others like this.
  14. Santhosh1997
    Donut Jun 8, 2020
  15. Trevor.Hawkes
    Thanks. I will try that.
    ironass and Caoimhín like this.
  16. LegolasX
    KitKat Jun 8, 2020
    LegolasX , Jun 8, 2020 :
    definitely sleep standby optimization.
    i have seen this kind of behavior in older versions of Android when i had Xperia. when on long standby the network is disconnected and resumes as soon as you unlock your phone.
  17. Patrick Trin
    Eclair Jun 8, 2020
    Patrick Trin , Jun 8, 2020 :
    yes, no problem, you can even use Oxygen Updater
  18. nagarjuna003
    nagarjuna003 , Jun 8, 2020 :
    camera capture not get good clarity picture and vedio capture getting dot line .
    total waste to buy a phone for not having good camera and good vedio capture.
    so many time request for checking the quality pictures in camera and vedio.but no use.
    other people also saying waste of paying that much for no quality in camera and vedio.
    don't know some people are taking pictures from one plus or from DSLR camera
    size of vedio and camera very high compare to other mobiles
  19. E1544196160689
    E1544196160689 , via OnePlus 6 , Jun 8, 2020 :
    i didnt get this update [e]1f625[/e][e]1f625[/e][e]1f625[/e][e]1f625[/e]and my battery was draining was very fast today wt does i do [e]1f625[/e][e]1f625[/e][e]1f625[/e]
  20. E1544196160689
    we have turn of the sleep mode....?
