320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. ankampra
    Donut Jul 31, 2020
    ankampra , via OnePlus 6 , Jul 31, 2020 :
    Thanks for suggestion,I will do and let you know
    Caomhin likes this.
  2. ShahPpArth
    Cupcake Jul 31, 2020
  3. Caomhin
    Marshmallow Jul 31, 2020
    Caomhin , via OnePlus 6T , Jul 31, 2020 :
    Or you can use 3rd party app Oxygen Updater from the Playstore as I and many others have done today.
    VinodhRajakumar likes this.
  4. VinodhRajakumar
    Caomhin likes this.
  5. ankurjain84
    Eclair Jul 31, 2020
    ankurjain84 , via OnePlus 6T , Jul 31, 2020 :
    I am updated thanks to Oxygen Updater. Well haven't noticed any changes yet. May be every improvement is under the hood.
    I am hoping for some battery life improvements. Update 10.3.4 reduced battery life on my phone.
  6. Teja1999 and Caomhin like this.
  7. RicRod
    Eclair Jul 31, 2020
    RicRod , via OnePlus 6T T-Mobile , Jul 31, 2020 :
    My one plus 6T from T-Mobile the same
  8. ItsRavi25
    Ice Cream Sandwich Jul 31, 2020
    ItsRavi25 , via OnePlus 6T , Jul 31, 2020 :
    Here is the link for incremental OTA... (10.3.5)
    ONEPLUS 6
    https://otafsg1.h2os.com/patch/amaz...gen_22_OTA_046-047_patch_2007191515_f9bd1.zip
    ONEPLUS 6T
    https://otafsg1.h2os.com/patch/amaz..._046-047_patch_2007171912_5566e9d41cbb5d6.zip
    Backup your all data
    Copy the zip to the root of your internal storage
    Go to Settings > System > System Updates
    Tap the gear icon top right, followed by 'Local upgrade'
    Read the warning and tap confirm
    rHITkM, ironass and Caomhin like this.
  9. ItsRavi25
    rHITkM likes this.
  10. J1530206876469
  11. colsareen
    colsareen , via OnePlus 6T , Jul 31, 2020 :
    I have 6T for about 2 yrs now. There are 2 issues being faced as follows: -
    1. While adding text on photographs can type only in WHITE or BLACK. Can not type in other colours.
    2. Data STOPS working whenever a call is received or made. I have tried on GIO and AIRTEL connections.
    Can a solution to above 2 problems be intimated. If these are due to some bugs then some rectification.
    Thanking you,
    Col AK Sareen.
    riprapzap likes this.
  12. stanyd93
  13. lyes87
    Gingerbread Jul 31, 2020
    lyes87 , via OnePlus 6 , Jul 31, 2020 :
    Even that the hardware still better than nord shit.
  14. Kubo_S
    Froyo Jul 31, 2020
  15. mik29194
    Froyo Jul 31, 2020
    Ronesso17 likes this.
  16. sumitMZ007
    Honeycomb Jul 31, 2020
    sumitMZ007 , via OnePlus 6 , Jul 31, 2020 :
    Stop taking weed in lockdown.. it's driving you crazy it seems.
  17. Caomhin
    No, you need to download the full 10.3.5 update zip and install over the Beta you are on.
    Not sure if the full update zip is available yet for 10.3.5.
    But you can download the 10.3.3 update zip from OnePlus support site, follow the instructions on the website to manually install.
    https://www.oneplus.com/support/softwareupgrade/details?code=PM1574156173727
    and then OTA to 10.3.5 from there or use the 3rd party app Oxygen Updater to update.
    drl431 and ItsRavi25 like this.
  18. kil0bite
    kil0bite , via OnePlus 6 , Jul 31, 2020 :
    Yes
  19. Pravs 2017
    Pravs 2017 , Jul 31, 2020 :
    where is the update??
