321
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. MR.HUNT07
    Donut Aug 10, 2020
    MR.HUNT07 , via OnePlus 6T , Aug 10, 2020 :
    If you want to lock your bootloader use msm tool.
  2. Alazu
    Donut Aug 10, 2020
    Alazu , via OnePlus 6T , Aug 10, 2020 :
    MR.HUNT07
    If you want to lock your bootloader use msm tool.​
    I think that is very low priority. I only wanted to get Netflix working and I already fixed that. Plus having an unlocked bootloader IMO has its benefits and it's slight downsides. I much prefer to keep it's upsides.
    Caomhin likes this.
  3. G1593694934552
    Cupcake Aug 10, 2020
    G1593694934552 , Aug 10, 2020 :
    Hi...after this update I am facing problem with voice calls as my frndzz,family and relatives are unable to hear my voice please do needfull and help me out of this.
  4. Caomhin
    Community Hero 2020 Aug 10, 2020
    Caomhin , via OnePlus 6T , Aug 10, 2020 :
    Reset your Mobile Network adapter.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    See if that helps.
    Auristic and zayn_ys like this.
  5. N1541244948719
  6. Caomhin
    Clear your Google Playstore App info Cache and App info Storage as well.
    Do the same for Google Play Services as well
    Restart the phone.
    See if that helps.
    Auristic, ItsRavi25 and zayn_ys like this.
  7. Matt.beddow
    Cupcake Aug 11, 2020
    Matt.beddow , Aug 11, 2020 :
    updates are great and everything but not when you break the basics like a clock.
    clock widget was broken with the last update, and still doesn't work properly...
  8. SamsungRefugee
    Froyo Aug 11, 2020
    SamsungRefugee , via OnePlus 6T , Aug 11, 2020 :
    Possible bug I'd like someone on 10.3.5 to see if they can replicate - I can't forward voicemail from the dialer. I press the 3 dot menu and select Forward, but nothing happens. I am using the built in OnePlus dialer. Not sure if version was updated in this patch.
  9. MR.HUNT07
    Donut Aug 11, 2020
    MR.HUNT07 , via OnePlus 6T , Aug 11, 2020 :
    Setup Voicemail first.
  10. SamsungRefugee
    Froyo Aug 11, 2020
  11. MR.HUNT07
    Donut Aug 11, 2020
    Go to settings- reset options - reset wifi, mobile & bluetooth
    May be it will solve your problem.
  12. jsoue124
    jsoue124 , via OnePlus 6 , Aug 11, 2020 :
    Already try that but the problem persists
  13. MR.HUNT07
    Donut Aug 11, 2020
    Visit Service center. There is no such issue. There must be some internal damage that's why this is heating up after a rest too
  14. adi1001
    Honeycomb Aug 11, 2020
  15. Navalture
    Eclair Aug 11, 2020
  16. Tee_Eee_Bee
    Ice Cream Sandwich Aug 11, 2020
    Tee_Eee_Bee , Aug 11, 2020 :
    If you go to Dialler App > Settings > Call Settings > Select Sim Card 1 or 2 > Call Forwarding you should be able to see what your current settings are.
    You should also be able to change them by tapping on them and entering the number you want to forward your calls to.
    If you are using a Network Provider's "short" code e.g. 123, check with them to make sure you are entering the number in the correct format - it may require something like +61 in front of it i.e. +61123
    • Where the "+" sign indicates to the network the international dialling code in your country
    • And the 61 is your country's IDD code. In this example, 61 is for Australia
    Auristic and Caomhin like this.
  17. V9YK
    Gingerbread Aug 11, 2020
  18. Koushik87
    Koushik87 , via OnePlus 6T , Aug 11, 2020 :
    Anything above 80 is normal. You are on the borderline, if you are heavy user and need to charge your phobe twice or thrice, you see sudden dip in battery from nowhere then may be you should get it replaced. If you are a casual user and battery gets through a complete day, then you can continue with it for another two to three months.
  19. V9YK
  20. W1597121371434
    W1597121371434 , Aug 11, 2020 :
    Right now 10.3.5 stable or not?
    current, I use 10.3.4 should be an update to 10.3.5 or not?
    Thank you.
