321
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 15, 2020
    Caomhin , via OnePlus 6T , Aug 15, 2020 :
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    OP6T Battery and Heating Thread
    https://forums.oneplus.com/threads/unified-op6t-battery-and-heating-thread.952987/
    ItsRavi25 likes this.
  2. Jaffer_Khan98
    Gingerbread Aug 15, 2020
    Jaffer_Khan98 , via OnePlus 6T , Aug 15, 2020 :
    After updating the OS to 10.3.5, all my apps are crashing including uc browser, chrome, x-plore, file manager and WhatsApp working wierd.
    Someone pls help me. I updated my OS using the Oxygen Updater via local upgrade
    Caoimhín likes this.
  3. Caomhin
    Same as that used Oxygen Updater, by my 6T has none of the issues you mention.
    With that many issues, I would suggest to back up your phone first. Then do a full Erase All Data factory reset.
  4. Jaffer_Khan98
    Okays will try this tonight. Ty
  5. edyaldea
    Froyo Aug 15, 2020
    edyaldea , Aug 15, 2020 :
    You not worth to be mentioned.
  6. Achyut230
    Eclair Aug 15, 2020
  7. rhyd1am
    KitKat Community Expert Aug 15, 2020
    Caoimhín, kjjm and ironass like this.
  8. Caomhin
    See, I'm his favourite slave, @rhyd1am gonna have to kowtow even more to get a pat on the head... 🤣🤣🤣🤣
    ItsRavi25, ironass and rhyd1am like this.
  9. Caomhin
    Which Beta are you on, as you will never receive Stable OTA updates while on the Beta Channel.
    If you are on an Android 10 Beta version.
    Then choose your model of phone in the list in the link below and download and install the Android 10.3.5 file, follow the instructions given on the OnePlus Software Support page, link below.
    https://www.oneplus.com/support/softwareupgrade
    ItsRavi25 and rhyd1am like this.
  10. rhyd1am
  11. hipy_10
    Donut Aug 15, 2020
    hipy_10 , Aug 15, 2020 :
    hello someone fails you in the at a glance weather? It disappeared for me and I have the location activated, I have deleted data from the Google app and it still does not appear, any advice?
  12. rhyd1am
    rhyd1am , via OnePlus 6T , Aug 15, 2020 :
    The at a glance widget has been the same on a lot of devices recently with weather. Personally I would guess that is a problem with the widget itself rather than an OS update, because the widget is not showing the weather on my son's Moto g7 either.
    you can download similar widgets from the playstore that are pretty much identical.
    I've been using this one until the issue gets sorted
    https://play.google.com/store/apps/details?id=com.tommasoberlose.anotherwidget
  13. VISHNUSINGH777
    Donut Aug 15, 2020
    VISHNUSINGH777 , via OnePlus 6T , Aug 15, 2020 :
    Chrome is still crashing even after this update please fix it, it is so annoying when try to touch our screen but screen freezes and 10 gb ram of you mclaren edition can't help a bit.[e]1f614[/e]
  14. hipy_10
    Donut Aug 15, 2020
    [QUOTE = "rhyd1am, publicación: 21980904, miembro: 928936"] El widget de un vistazo ha sido el mismo en muchos dispositivos recientemente con el clima. Personalmente, supongo que es un problema con el widget en sí en lugar de una actualización del sistema operativo, porque el widget tampoco muestra el clima en el Moto g7 de mi hijo. [/ QUOTE]
    thank you very much for your answer very grateful
    Caoimhín and rhyd1am like this.
  15. rhyd1am
    No problem [e]1f44d[/e]
  16. V1559213281740
    Cupcake Aug 15, 2020
  17. Caomhin
    It's a known Google Chrome issue presently, revert to an older version, or update the version you have
    Chrome 84 hangs and crashes for some, especially when they close incognito tabs
    https://www.androidpolice.com/2020/...me-especially-when-they-close-incognito-tabs/
    [e]25b6[/e]️ New Chrome update available from the Playstore in the last few days [e]25c0[/e]️
    You could also try the following.
    Clear Chrome App info Cache.
    Also open Chrome, go to Settings>Site Settings>Storage click on Clear Site Storage.
    Also clear browsing history in Chrome Settings>Privacy>Clear Browsing Data. Select All Time for the Time Range, then Clear Data.
    See if that helps.
  18. Caomhin
    As per @B_Wrath pinned post on 10.3.3 thread
    https://forums.oneplus.com/threads/oxygenos-10-3-3-for-the-oneplus-6-and-6t.1218405/
    [e]25b6[/e]️ Backup your Downloads folder [e]25c0[/e]️
    I am not able to access the storage, Google play crashes, gallery is empty.
    Delete the data and cache of downloads app and download manager. This should fix the problem.
    Thanks to @NodePoint for finding the solution.
    Q: How to access the downloads and download manager app?
    A:
    Step 1: Unlock your phone.
    Step 2: Open app drawer and locate settings app / bring down the QS panel and click on the gear icon.
    Step 3: Click on the search tab on top of the settings app.
    Step 4: Type "downloads" and then click on the app. Clear it's cache and storage which is under the storage tab.
    Step 5: Type "download manager" and then click on the app. Clear it's cache and storage which is under the storage tab.
  19. V1559213281740
    V1559213281740 , Aug 15, 2020 :
    not about missing all my photos some of means what's up received pics rarely missing not regularly
  20. Caomhin
    Sorry I don't fully understand what you mean, write it in your own language with more details, and I'll translate it [e]1f44d[/e]
