320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. metadethrax
    Cupcake Jul 31, 2020
    metadethrax , Jul 31, 2020 :
    Since updating to 10.3.5 on my 6T there is a display problem with the Card package widget in shelf and the normal widget, as seen in the attached screenshot. Only two cards appear, no matter how big the widget is and cards' shape looks wierd.
    https://photos.app.goo.gl/mex5X5isKKHtMaL1A
    Clearing cache of the Card package app or the launcher did not solve the problem.
  2. bittech
    Eclair Jul 31, 2020
  3. rhyd1am
    KitKat Jul 31, 2020
    rhyd1am , via OnePlus 6T , Jul 31, 2020 :
    Yep same here. Although if you tap more the rest of them appear. Just making things look nearer I guess 🤷‍♂️
    Caoimhín likes this.
  4. rhyd1am
    KitKat Jul 31, 2020
    The link does work. Hit the 3 dots in the top right after tapping on the link and select "open with browser"
    drl431, ironass and Caoimhín like this.
  5. D1570603511759
  6. OP_Samarth_Mishra
    Eclair Jul 31, 2020
    OP_Samarth_Mishra , via OnePlus 6 , Jul 31, 2020 :
    Actually Yes,
    I've been using Oxygen updater since the Android 10 update.
    My main reason to use the updater was because the staged roll out reached too late for me. Once it took more than 2 weeks, still I didn't get the update after which I used the updater.
    Incidentally, today I recieved the system update directly from the settings update segment.
  7. D.Sai Suhail Baba and Caoimhín like this.
  8. disaur
  9. rhyd1am
    KitKat Jul 31, 2020
    Caoimhín, drl431 and ironass like this.
  10. edyaldea
    Froyo Jul 31, 2020
  11. kjjm, Caoimhín and drl431 like this.
  12. rhyd1am
    KitKat Jul 31, 2020
    edyaldea
    Another fail from garbage team zerominus!​
    Some nice insightful and constructive input there. Any particular issues with the 10.3.5 update? Or are we all meant to guess? 🤷‍♂️
    Or maybe it's just your now traditional rant after every android 10 update.
    jotei66, kjjm, Caoimhín and 2 others like this.
  13. THE PRANJAL
    THE PRANJAL , via OnePlus 6T , Jul 31, 2020 :
    my op 6t is on 10.3.4 and facing screen calibration issue . I set it to vivid it works for some time and then suddenly all the colours on the screen changes to advance amoled wide gamut automatically and if i check the same in settings it shows it is already set on vivid .I did clear cache and updated op launcher but nothing work.
  14. jp4lm
    Gingerbread Jul 31, 2020
    jp4lm , via OnePlus 6 , Jul 31, 2020 :
    I got some bugs after incremental update so I did a system reset and it seems run smoothly after that. Backup your device before reset/wipe
  15. U1593278460200
    U1593278460200 , Jul 31, 2020 :
    not downloading
  16. ARX007
    Froyo Jul 31, 2020
    ARX007 , Jul 31, 2020 :
    Still eagerly waiting for the bullets wireless z latency issue to be fixed to what they actually advertised.
  17. jainhardik0311
    Eclair Jul 31, 2020
    jainhardik0311 , via OnePlus 6T , Jul 31, 2020 :
    Yes you will receive OTA updates.
