320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Ericb3800
    Donut Jul 31, 2020
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 1, 2020
    Caomhin , via OnePlus 6T , Aug 1, 2020 :
    Fast charge is not broken, works fine for the majority, however sometimes cleaning the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully may fix it.
    If still an issue, backup your phone data and do a full Erase All Data factory reset.
    If it still doesn't work then it could be a charger issue, possibly the cable and finally the USB C port on the phone giving an issue.
    In which case you might need to bring it to an approved OnePlus service center and get them to check it out for you.
    drl431 likes this.
  3. Caomhin
    Update to 10.3.5 and see if that may help with the issue.
    If not, try the OnePlus Diagnostic tool and check if there are issues with hardware on the phone.
    Just follow the instructions on the screen.
    Details of the OnePlus Diagnostic tool.
    https://www.xda-developers.com/onep...eres-how-to-check-the-health-of-your-battery/
    Download OnePlus Diagnostic tool.
    https://www.apkmirror.com/apk/oneplus-ltd/oneplus-diagnostic/
    ItsRavi25 likes this.
  4. Caomhin
    Who knows, this is the 6 series thread, all users here. Check on 7 series threads.
  5. Caomhin
    Did you download the correct zip file for OP6T, this usually happens if you download the incorrect zip file.
    ironass likes this.
  6. disaur
    Cupcake Aug 1, 2020
    disaur , via OnePlus 6T , Aug 1, 2020 :
    Yeah. Pretty sure I had the correct one since I would have used the full ota rom otherwise considering the only available zip is the incremental one.
  7. den_semenov
    Froyo Aug 1, 2020
  8. Caomhin
    Only other reason would be a corruption of the file downloaded, you may have to delete the downloaded file and try again.
    Did you get it via OTA or Oxygen Updater. If Oxygen Updater, go to Settings to check that the Device setting is set to your phone 6T
  9. Caomhin
    Personally have never had an issue with Adaptive brightness. Works fine. What happens with yours?
  10. disaur
    Cupcake Aug 1, 2020
    Yup, also tried with the Oxygen Updater and after downloading for several times still no go. I've also attempted the automatic installation option in the updater but that just booted the phone into twrp and did nothing.
  11. Caomhin
    Aaah right, your phone is rooted?
    Depending on the way you rooted it, it may affect the way you update it.
    Gonna call on @ironass to check into this for you, he would be the root expert there and may be able to explain how to do it.
    Maybe give some info on the way you have the phone rooted and do you run Magisk, and if so which version, also which version of TWRP you have installed. Not sure how quick he will get back to you. But he would be able to guide you right.
    ItsRavi25, ironass and disaur like this.
  12. GauravaRai
    Honeycomb Aug 1, 2020
    GauravaRai , via OnePlus 6 , Aug 1, 2020 :
    A small question. Suppose I have installed 10.3.5 but I want to rollback to some previous OOS 10 or OOS 9 version what will be the roll back package...?
  13. Caomhin
    You can use any previous version as a zip file, but check the link below as to the procedure to rollback, as it also involves a phone wipe. You will need to backup your data.
    ROLL-BACK FROM CURRENT ANDROID 10 Stable TO EARLIER STOCK ANDROID 9 OR 10
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    Thanks to @ironass for putting this together.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    And here is a seperate guide to bring you straight back to Android 9 if you wish to go that far back.
    https://wccftech.com/how-to/downgrade-android-10-to-android-9-pie-on-oneplus-6t-6-guide/
  14. disaur
    Cupcake Aug 1, 2020
    I'm running Magisk 12.4, TWRP 3.3.1-32 with blu spark kernel.
    Thanks man!
    Caoimhín likes this.
  15. Flewoutcuckoonut
    Gingerbread Aug 1, 2020
    Flewoutcuckoonut , via OnePlus 6T , Aug 1, 2020 :
    Caomhin
    Personally have never had an issue with Adaptive brightness. Works fine. What happens with yours?​
    The automatic adjustment is not sensitive enough
    For some occasions, the brightness is not light enough to view the screen
    i am just wondering if this version has any bugss....
  16. Caomhin
    Am running it all day and it appears to be fine, but then there wasn't an issue before. I know it can take a couple of seconds to adjust depending on lighting conditions, which I find fine. All I can say is that it is adjusting in 10.3.5 the same as previously in mine.
  17. Flewoutcuckoonut
    So you are already on 10.3.5?
  18. Sanky8990
    Froyo Aug 1, 2020
    Sanky8990 , via OnePlus 6 , Aug 1, 2020 :
    Yes brother, Waiting for Oneplus 6 to get that.
    It's working on 6t or not? (as they advertised)
    ARX007 likes this.
  19. Harsh.Gada
    Cupcake Aug 1, 2020
  20. Harsh.Gada
    Cupcake Aug 1, 2020
    Harsh.Gada , Aug 1, 2020 :
    I haven't got any notification.
