320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. R1546433408005
    Donut Sep 6, 2020
    R1546433408005 , via OnePlus 6T , Sep 6, 2020 :
    I didn't get this update as well, I'm a 6t user.. I comment that as well, somebody help me to get this update , and I did it..now my phone up to date with all security's renewed to July, (which is the latest If I'm not wrong), so for the update you have to search this (OnePlus/downloads&updates) in Google. Then you can select your device and latest update, just download it and install it manually,
  2. anup1111
    Cupcake Sep 6, 2020
  3. drl431
    Nougat Sep 6, 2020
    drl431 , Sep 6, 2020 :
    Then you have to do some housekeeping;
    Clear the cache and storage from the "downloads" app.
    Clear the cache and storage from the "download manager" app.
    Then restart the phone.
    rhyd1am, Caomhin and ItsRavi25 like this.
  4. Caomhin
    Marshmallow Sep 6, 2020
    Caomhin , via OnePlus 6T , Sep 6, 2020 :
    If you are currently on Android 10 Beta or any version on Android 10 Stable then follow the steps below.
    If you are on a previous version such as Android 9 then check the addition info below.
    For those already on a Version of either Beta or Stable Android 10 OOS
    Then choose your model of phone in the list in the link below and download and install the Android 10.3.5 file, follow the instructions given on the OnePlus Software Support page, link below.
    https://www.oneplus.com/support/softwareupgrade
    Only for those who are on Android 9 and want to Upgrade to 10
    If you have a OnePlus 6 you need to download and install OOS 9.0.9 as this contains files to allow you to update to Android 10.
    Download 9.0.9 for OnePlus 6 from link below.
    https://oneplusupdates.com/device/oneplus-6
    If you are OnePlus 6T you need to download and install OOS 9.0.17 as this contains files to allow you to update to Android 10.
    Download 9.0.17 for OnePlus 6T from link below.
    https://oneplusupdates.com/device/oneplus-6t
    [e]26a0[/e]️Make sure you download the correct file for the model of phone you have. [e]26a0[/e]️
  5. Lerchu
    Cupcake Sep 6, 2020
    Lerchu , via OnePlus 6T , Sep 6, 2020 :
    In other versions there is also a black screen problem. The phone works normally 70-100% below black screen.Maybe it's the battery's fault?[e]1f614[/e]
  6. anup1111
    Cupcake Sep 6, 2020
    anup1111 , via OnePlus 6T , Sep 6, 2020 :
    Problem solve thanks
    ironass and drl431 like this.
  7. drl431
    Nougat Sep 6, 2020
    Great, thanks for the reply.
    Auristic, ironass and Caomhin like this.
  8. mohal
    Ice Cream Sandwich Sep 7, 2020
  9. E1542593350065
    Cupcake Sep 7, 2020
  10. Caomhin
    Marshmallow Sep 7, 2020
    Caomhin , via OnePlus 6T , Sep 7, 2020 :
    Go to the link below choose your phone model and follow the steps given on the downloads page in order to install 10.3.5 Stable.
    It is always recommended to make a backup before installing, however you should not lose anything if upgrading from OOS 10 Beta versions.
    Auristic and ItsRavi25 like this.
  11. pvilarinho74
    Honeycomb Sep 7, 2020
    pvilarinho74 , via OnePlus 6 , Sep 7, 2020 :
    Just popped up to say that there's nothing wrong with my phone, smooth as day one, battery could be better but I've to take into consideration that's an aging phone. Ah! No bugs either, at least that I've noticed.
    kjjm, Caomhin and DosenHatti like this.
  12. Sanky8990
    Froyo Sep 8, 2020
    Hima_Sumanth likes this.
  13. Ján Hirner
    Gingerbread Sep 8, 2020
    Ján Hirner , Sep 8, 2020 :
    I just tell you what I should to do:
    1. reflash with 10.3.5 latest stable version
    2. wipe cache through recovery
    3. restart and see, must work, ...
    if doesnt help it will be probably hardware problem.
    Caomhin likes this.
  14. Abhishek_Singh_2
    Honeycomb Sep 8, 2020
    Abhishek_Singh_2 , via OnePlus 6T , Sep 8, 2020 :
    Even I'm facing the same
    Wait for the future updates they may fix it.
  15. pavan.kumar.p
    Cupcake Sep 8, 2020
    pavan.kumar.p , via OnePlus 6T , Sep 8, 2020 :
    It's been a month and 8 days after update of 10.3.5 there is no new update for 6t.
    Requirements as per mi ui :
    1.there are no new Font style , only default are there
    2. Themes also not available
    3. No floating window
    4. No one handed mode
    5. Etc. Etc.etc
  16. Caomhin
    Marshmallow Sep 8, 2020
    Caomhin , via OnePlus 6T , Sep 8, 2020 :
    OP6 Series phones are at the bottom of the update cycle, you will receive updates on a bimonthly basis as has happened for the last few updates. Doubt if any new features will be added just bugs and security updates.
    When Android 11 appears sometime Q1 or Q2 next year you will get the features within that for OOS 11. Might be a Beta before in Q1 before a Stable release in Q2. And you will then no longer receive any kind of update from about Q3 onwards.
    Be time for the custom ROMs or a new phone whichever you prefer, though Android OOS 11 will be fine to run for eternity.
  17. kokoon88
    Cupcake Sep 8, 2020
  18. U1534277395997
    Cupcake Sep 8, 2020
    U1534277395997 , via OnePlus 6 , Sep 8, 2020 :
    Hello, my son and I both have the 6 and since the update, neither of us are able to have direct calls!
    The calls go through but we can't hear or be heard. I spoke to my network provider and tested my sim on another phone (not OnePlus) and it worked.
    What can urgently be done??
  19. U1534277395997
    Cupcake Sep 8, 2020
    U1534277395997 , Sep 8, 2020 :
  20. Caomhin
    Settings, Display, Screen Saver, When to Start choose Never.
    ItsRavi25 likes this.
