296
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. famejs
    Cupcake Sep 13, 2020
    famejs , via OnePlus 6 , Sep 13, 2020 :
    is anyone else facing problems updating Chrome and Android Messages?
    i have no problem updating other apps but when it comes to the two it's always "download pending" or it will start but never finish.
    Parmarsanjay431 likes this.
  2. Caomhin
    Marshmallow Sep 13, 2020
    Caomhin , via OnePlus 6T , Sep 13, 2020 :
    Clear the Playstore App info Cache and App info Storage as well.
    See if that helps.
  3. famejs
    i have tried that several times and i just did just in case but still no help
    the thing is one day i will tap update and it will but mostly it won't
  4. Ján Hirner
    Gingerbread Sep 13, 2020
    D.Sai Suhail Baba and Caomhin like this.
  5. Patel_Nihar_1987
  6. Patel_Nihar_1987
  7. Caomhin
    Clear all Screen Locks, Pin, Fingerprint and Facelocks etc
    Also clear all Smart Locks as well
    Restart the phone
    Setup the Fingerprint once more
    See if that helps
    zayn_ys, drl431 and ItsRavi25 like this.
  8. Patel_Nihar_1987
  9. Caomhin
    Then you have not cleared All the Screen Locks. Clear the pin, clear any Fingerprints, and Clear all Facelocks and any other Screen Locks.
    Basically when you reboot the phone there should be no security requests for Pin, Fingerprint and Facelocks etc.
    You then set it back up fresh in Security & Lockscreen
    If its still giving issues, then backup your phone and do a full Erase All Data factory reset. To refresh the OOS.
  10. Patel_Nihar_1987
  11. Caomhin
    Links on how to back up your phone below.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    [e]26a0[/e]️Enable Erase Internal Storage[e]26a0[/e]️
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    zayn_ys, drl431, ItsRavi25 and 2 others like this.
  12. Teja1999
    Froyo Sep 13, 2020
  13. Caomhin
    OnePlus don't give that info, however China specific Hydrogen OS usually comes out about a week prior to International Oxygen OS, so you may get an insight what to expect, about a week beforehand.
    Next update will probably be at the end of this month, and will be Bug and Security updates. Doubt there will be features added until Android 11 is released for the 6 Series in Q2 next year.
  14. ashok_inder
    Froyo Sep 13, 2020
    ashok_inder , via OnePlus 6 , Sep 13, 2020 :
    Don't worry the update will happen. The issue is that google is now slowly releasing .apkm bundles which are kind of delta apk which misses some dependency packages that gets compiled during installation. This issue of some gapps not getting installed is because of that. Basically your downloading does not start as its trying to resolve those dependency but is not doing it well. Take for eg: new chrome installation needs a new app called trichrome library. So after few updates of other apps your these stuck apps will also get uploaded.
    You can also try to use some other internet connection gateway as well. For me these worked a few times. I can't say exact problem as my phone is not rooted so can't check the logs.
    famejs likes this.
  15. famejs
    thanks
  16. O1562734928562
    Cupcake Sep 14, 2020 at 8:28 AM
  17. ItsRavi25
    Ice Cream Sandwich Sep 14, 2020 at 9:41 AM
    ItsRavi25 , via OnePlus 6T , Sep 14, 2020 at 9:41 AM :
    This may be display issue, visit nearby service center.
    Caomhin likes this.
  18. Caomhin
    Marshmallow Sep 14, 2020 at 11:44 AM
    Caomhin , via OnePlus 6T , Sep 14, 2020 at 11:44 AM :
    You could also try the OnePlus Diagnostic tool, if it shows errors then you may need to do a a backup of the phone and then full Erase All Data factory reset to be sure its not the OOS. If it still persists then bring it to an Approved OnePlus service center to check the hardware.
    You can run this tool to check if everything is working as expected by clicking on Detect Now.
    Just follow the instructions on the screen.
    Download OnePlus Diagnostic tool.
    https://www.apkmirror.com/apk/oneplus-ltd/oneplus-diagnostic/
    zayn_ys and ItsRavi25 like this.
  19. rakeshgergal
    Eclair Sep 14, 2020 at 12:00 PM
  20. Caomhin
    Marshmallow Sep 14, 2020 at 12:30 PM
    Caomhin , via OnePlus 6T , Sep 14, 2020 at 12:30 PM :
    Try to Optimize the phone, this helps with Lag, Heat, Battery Drain and much more.
    Clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Guide to lower Battery Drain.
    drl431, rakeshgergal, zayn_ys and 2 others like this.
