296
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Royal_RJ
    Gingerbread Sep 14, 2020 at 1:14 PM
    Royal_RJ , via OnePlus 6 , Sep 14, 2020 at 1:14 PM :
    Anyone heve any idea what we got in 10.3.6 because yet we get limit things and only security patch in last update so I just want to know anyone who confirm something on it.
  2. kouzelnik3
    Honeycomb Sep 14, 2020 at 2:04 PM
    kouzelnik3 , via OnePlus 6 , Sep 14, 2020 at 2:04 PM :
    I would not expect much because there is android 11 in progress which might be available for us about early 2021 so all work is probably aimed there.
    BRAD FORD BOI and Caomhin like this.
  3. Caomhin
    Marshmallow Sep 14, 2020 at 2:05 PM
    Caomhin , via OnePlus 6T , Sep 14, 2020 at 2:05 PM :
    OnePlus have never given that info prior to release previously, and I doubt they will change that strategy now for any new releases
    But as this phone series is either over, OP6, or just under 2 years old now, OP6T, and going by OP5 series at the same stage of life, it will just be Bug fixes and Security updates, with no feature updates, until Android 11 is released around Q1 or Q2 next year.
  4. Royal_RJ
    Gingerbread Sep 14, 2020 at 3:06 PM
    Royal_RJ , via OnePlus 6 , Sep 14, 2020 at 3:06 PM :
    Ok then waiting for that which we get at the end of this month.
  5. Caomhin
    Marshmallow Sep 14, 2020 at 3:23 PM
    Caomhin , via OnePlus 6T , Sep 14, 2020 at 3:23 PM :
    Approximately at the end of the month, that seems to be the schedule for bimonthly updates.
  6. Royal_RJ
    Gingerbread Sep 14, 2020 at 3:25 PM
    Royal_RJ , via OnePlus 6 , Sep 14, 2020 at 3:25 PM :
    Ya I know that's why I told you at the end of this month but I expect befor 27th because there is no specific date for any update just after 2 months which is committed by OnePlus.
  7. ironass
    Lollipop Sep 14, 2020 at 6:01 PM
    ironass , Sep 14, 2020 at 6:01 PM :
    Last update came out on the 31st July. :rolleyes:
    Auristic, drl431 and Caomhin like this.
  8. sagarshah20
    Froyo Sep 14, 2020 at 6:36 PM
  9. marky1124
    Cupcake Sep 15, 2020 at 11:58 AM
    marky1124 , Sep 15, 2020 at 11:58 AM :
    I upgraded to 10.3.5 a few months ago and since that upgrade I find that I sometimes need to reboot my phone to hear my podcasts in my OnePlus wireless bullets. They show as connected and have plenty of charge, but just no audio from the podcast player (podcastaddict). The system connect and disconnect sounds do still happen. After the reboot they always work.
  10. Caomhin
    Marshmallow Sep 15, 2020 at 12:06 PM
    Caomhin , via OnePlus 6T , Sep 15, 2020 at 12:06 PM :
    Try reset the Bluetooth on the phone
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    Restart the phone
    Also reset the Bluetooth on the wireless Bullets as well, check the device manual on how that is done.
    Then pair them up again and see if that can help.
    ItsRavi25 and marky1124 like this.
  11. marky1124
    Cupcake Sep 15, 2020 at 12:23 PM
    marky1124 , Sep 15, 2020 at 12:23 PM :
    Thank you for the tip. I'll save it for now as the lose of all my WiFi, mobile & Bluetooth settings is too high a price to pay. I'll revisit of it gets worse or isn't fixed by the next oxygenos release.
    Caomhin likes this.
  12. Caomhin
    Marshmallow Sep 15, 2020 at 12:30 PM
    Caomhin , via OnePlus 6T , Sep 15, 2020 at 12:30 PM :
    No problem [e]1f44d[/e]😎
    ItsRavi25 likes this.
  13. KuldeepAhuja
    Cupcake Sep 15, 2020 at 12:46 PM
  14. drl431
    Nougat Sep 15, 2020 at 1:00 PM
    drl431 , Sep 15, 2020 at 1:00 PM :
    Hi, my OP6 seems fine with 10.3.5, but you can try resetting the networks:
    Settings > System > Reset options > Reset WiFi, mobile & Bluetooth.
    ItsRavi25, ironass and Caomhin like this.
  15. nunact
    Cupcake Sep 15, 2020 at 3:05 PM
  16. ItsRavi25
    Ice Cream Sandwich Sep 15, 2020 at 5:59 PM
  17. S1599119672796
    Cupcake Sep 15, 2020 at 6:58 PM
    S1599119672796 , Sep 15, 2020 at 6:58 PM :
    my OnePlus 6 phone is turning off and unable to use from past 2 weeks.Tried all the possible trouble shooting steps abs even did factory reset. Still no luck.i have posted asking for suggetion on the same. request to respond.
  18. Caomhin
    Marshmallow Sep 15, 2020 at 7:05 PM
    Caomhin , via OnePlus 6T , Sep 15, 2020 at 7:05 PM :
    Try running the OnePlus Diagnostic tool to see if it shows up any faults.
    You can run this tool to check if everything is working as expected by clicking on Detect Now.
    Just follow the instructions on the screen.
    Download OnePlus Diagnostic tool.
    https://www.apkmirror.com/apk/oneplus-ltd/oneplus-diagnostic/
    drl431, Auristic and ItsRavi25 like this.
  19. X1535307135560
    Cupcake Sep 15, 2020 at 7:19 PM
  20. Caomhin
    Marshmallow Sep 15, 2020 at 7:23 PM
    Caomhin , via OnePlus 6T , Sep 15, 2020 at 7:23 PM :
    If you are on Android 10 Beta follow the steps below to download and manually install Stable 10.3.5
    You should not lose anything, however it is always good practice to back up your phone first.
    Choose your model of phone in the list in the link below and download and install the Android 10.3.5 file, follow the instructions given on the OnePlus Software Support page, link below.
    https://www.oneplus.com/support/softwareupgrade
