305
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Z1597068515715
    Cupcake Sep 17, 2020
  2. brmbjn
    Gingerbread Sep 17, 2020
    brmbjn , Sep 17, 2020 :
    is there an update for op6 with september security patch available?
    Santoshtheone likes this.
  3. Auristic
    KitKat Sep 17, 2020
    Auristic , Sep 17, 2020 :
    No.
    drl431 likes this.
  4. Z1597068515715
  5. Z1597068515715
  6. Caomhin
    Marshmallow Sep 17, 2020
  7. Manas_CHABRIA
  8. Caomhin
    Caomhin , via OnePlus 6T , Sep 17, 2020 :
    What calibration?
    What version of OOS are you currently on?
    ItsRavi25, drl431 and rhyd1am like this.
  9. tarinimishra
    Froyo Sep 17, 2020
  10. Caomhin
    If you bothered to look 4 or 5 posts up before posting and throughout several recent pages in this thread you would get your answer. Check the posts up [e]2b06[/e]️[e]2b06[/e]️ the way. 🙄🙄
    ItsRavi25, drl431, ironass and 3 others like this.
  11. tarinimishra
    Froyo Sep 17, 2020
    tarinimishra , via OnePlus 6 , Sep 17, 2020 :
    Thanks. Got my answer.
  12. Saenz4931
    Honeycomb Sep 17, 2020
    Saenz4931 , via OnePlus 6T , Sep 17, 2020 :
    After doing the Google update,. For some reason I got a new file app,. And it seems to be a system app as I can't delete it. Anyone have noticed this new app?
  13. Caomhin
    Have had that quite a while now. So not sure why you only see it now, I think that came with Android 10.
    Check the App Info to see if it is the same version.
    You can see more details here.
    https://www.androidpolice.com/2019/...app-with-filters-and-updated-material-theme/?amp
    ItsRavi25 likes this.
  14. H1535106412349
    Donut Sep 17, 2020
  15. Tee_Eee_Bee
    Ice Cream Sandwich Sep 18, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Sep 18, 2020 :
    OnePlus have only released Android 11 open beta for the 8 series (8/8Pro). No other devices have received an A11 update as yet.
    6/6T will hopefully get it by the middle of next year, similar to how the 5/5T received an Android 10 open beta.
    kjjm, Caomhin, Auristic and 1 other person like this.
  16. rhyd1am
    Jelly Bean Sep 18, 2020
    rhyd1am , via OnePlus Community App , Sep 18, 2020 :
    How is it unfair that the 6 series haven't had Android 11 yet? That's how update cycles work 🤷‍♂️
    AyazIsayev, Auristic, kjjm and 2 others like this.
  17. vikkvikk
    Eclair Sep 18, 2020
    vikkvikk , Sep 18, 2020 :
    To COD players...(OnePlus 6)
    I recently received OnePlus launcher update and after the update cod stopped working on WiFi reporting unstable network connection. It was working fine on mobile data.
    WiFi was fine for every other App.I tried the regular restart,clear and reinstall to no use.
    Then as last option I tried switching off battery optimization for cod and it worked. WiFi working fine at 10ms ping without any error about unstable connection.
    Hope this helps someone facing same issue.
  18. D.Sai Suhail Baba
    Honeycomb Sep 18, 2020
    D.Sai Suhail Baba , Sep 18, 2020 :
    I hope [e]1f446[/e] this will help you but update schedule may change based on Beta updates and Software compatibility issues with OnePlus devices
