321
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. amanps
    Gingerbread Sep 19, 2020
  2. mohal
    Ice Cream Sandwich Sep 19, 2020
  3. Godfather 1
    Jelly Bean Sep 19, 2020
    Godfather 1 , Sep 19, 2020 :
    All the new features might come in OOS11 for 6/6t.
    Not all..but most of em
    @araj, drl431, Caomhin and 1 other person like this.
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 19, 2020
    Caomhin , via OnePlus 6T , Sep 19, 2020 :
    Check 6 posts up and even posts 2 pages up, you will get your answer
  5. Caomhin
    That's right, only for 7 series and up I believe. Won't be any new or updated features for 6 series phones until Android 11 next year sometime.
  6. D.Sai Suhail Baba
    D.Sai Suhail Baba , Sep 19, 2020 :
    I hope [e]1f446[/e] this will help you but update schedule may change based on Beta updates and Software compatibility issues with OnePlus devices.
    mohal and Caomhin like this.
  7. mohal
    mohal , via OnePlus 6T , Sep 19, 2020 :
    U should right only words yes or no instead of lecture my friend.
  8. Godfather 1
    You should read the thread properly..
    rhyd1am, kjjm, ironass and 2 others like this.
  9. Caomhin
    I have several time, as I mention, a few posts up, and repetitively many times over a few pages up. People just need to read or search before posting as is states in the Community guidelines. It's a simple concept.
  10. Koushik87
    Koushik87 , via OnePlus 6T , Sep 19, 2020 :
    My wallpapers went missing after launcher update to version 4.7.3. I have faced this issues earlier as well. Tried installing the OnePlus wallpaper resources but that doesn't help. Any suggestions how this can be fixed. I am currently on OOS 10.3.5.
  11. D.Sai Suhail Baba
    It's because of change in software strings
    Caomhin likes this.
  12. D.Sai Suhail Baba
    This will happen when a user tried ADB shell to activate some app's and their settings. If they won't deactivate the adb shell they use it may cause some issues like wallpapers missing or due to some app's that override system settings.
    Caomhin likes this.
  13. Koushik87
    I know the issue but I am looking for the solution. I did a bit of research before posting in forum. What I could find is - suggestions to reinstall the wallpaper resources app. Are you aware of any other solution?
  14. D.Sai Suhail Baba
    I tried same solution like you we can't do nothing but have to wait for OS 11 update so that it can override some system settings to default or can use magisk root
    Caomhin likes this.
  15. X1535584246691
    Cupcake Sep 19, 2020
    X1535584246691 , via OnePlus 6 , Sep 19, 2020 :
    Per piacere mi aiuta,ho un Oneplus6 e da poco hanno installato un Tore ripetitore di Tim ,e ho cambiato Sim per un Tim sim,ma con questo cellulare non riesco prendere 4g in casa,la ripetitore e 200 metre di distanza e funziona solo con 2 e 3 g quando lo metto sul 4g non riesco a fare né ricevere chiamate,,con delle altre marche di cellulare prende,Tim ha verificato e non possono più fare niente,mi dica cosa e la causa di questa inconvenienza ?? Grazie mille in anticipo
  16. amanps
    amanps , via OnePlus 6 , Sep 19, 2020 :
    Same problem in oneplus 7 series
  17. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 20, 2020
    Caomhin , via OnePlus 6T , Sep 20, 2020 :
    This is the translation of what you stated.
    Please help me, I have an Oneplus6 and have recently installed a Tore repeater by Tim, and I changed Sim for a Tim sim, but with this mobile I can not take 4g at home, the repeater is 200 meters away and it only works with 2 and 3 g when I put it on 4g I can not make or receive calls ,, with other brands of cell phone it takes, Tim has checked and they can no longer do anything, tell me what and the cause of this problem? Many thanks in advance.
    A repeater for 4g works separate from the 4g signal itself. You may or may not get the signal desired. It's nothing to do with the phone, and all to do with the device. Contact the device maker to fix the issue
    zayn_ys, Auristic and ironass like this.
  18. Caomhin
    zayn_ys and Auristic like this.
  19. mohal
    Ice Cream Sandwich Sep 20, 2020
  20. rutwikparmar
    Eclair Sep 20, 2020
