320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Caomhin
    Marshmallow Sep 25, 2020
    Caomhin , via OnePlus 6T , Sep 25, 2020 :
    And you think wrong.
    We are in within 3rd year for 6 series phones. You are still in denial about it all for some reason.
    Anyway, the next update will be here in a few days, and the one after that will be 2 months away end of November. Bi-monthly as stated, and as has been happening for the last few updates. 😎[e]1f44d[/e]
    Auristic, ItsRavi25, ironass and 3 others like this.
  2. kouzelnik3
    Honeycomb Sep 25, 2020
    kouzelnik3 , via OnePlus 6 , Sep 25, 2020 :
    Be happy with this frequency of updates because not many oems have updates released for its phones that often and even they don't care that much about their phones if they are half and year old.
    Auristic and D.Sai Suhail Baba like this.
  3. K1585077601005
    Cupcake Sep 26, 2020
    K1585077601005 , via OnePlus 6 , Sep 26, 2020 :
    Does anyone Facing The network problem issue? I've been facing it for 3 weeks[e]1f625[/e].The network signal Stays always poor and sometimes it goes away.I can't make phone calls or received calls.But The cellular data can be opened and it is disconnected after a few seconds automatically.I can send sms or received sms from anywhere.I can't understand where is the problem[e]1f625[/e].I exchanged my SIM card into another phone and it’s working ok.Now what should i do?
  4. Caomhin
    Marshmallow Sep 26, 2020
    Caomhin , via OnePlus 6T , Sep 26, 2020 :
    Reset your Network Adapters
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Reboot the phone.
    If that doesn't work, then contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    ItsRavi25, Auristic and drl431 like this.
  5. K1585077601005
    I've already reset the network settings more than four times,but It Doesn't work.I contacted oneplus with live chat,they told me to reinstall the OTA.I did it too,but No changes has been happened [e]1f625[/e]. I geuss it is Network IC related issue,but if it network IC related issue,then How could i opened cellular data?or the cellular data worked?how? I can't understand anything[e]1f623[/e]
  6. Caomhin
    As you say, you have reset the device already, and reset network.
    You could also try the OnePlus Diagnostic tool to see if there are hardware issues
    This is the OnePlus Diagnostic tool.
    You can run this tool to check if everything is working as expected by clicking on Detect Now.
    Just follow the instructions on the screen.
    Download OnePlus Diagnostic tool.
    https://www.apkmirror.com/apk/oneplus-ltd/oneplus-diagnostic/
  7. drl431
    Nougat Sep 26, 2020
    drl431 , Sep 26, 2020 :
    Also, check and ensure the electrical contacts on the sim card are clean. And if the sim card is more than a few years old, consider replacing it.
    ItsRavi25, Auristic and Caomhin like this.
  8. K1585077601005
    I've already replaced the sim card about 1 week ago.No changes.
  9. K1585077601005
  10. ahmedhamzam
    Froyo Sep 26, 2020
  11. Caomhin
    If its restarting regularly, then try the following.
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    [e]26a0[/e]️Enable Erase Internal Storage[e]26a0[/e]️
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    ItsRavi25, drl431 and Auristic like this.
  12. Caomhin
  13. K1585077601005
    I want to Downgrade the OS version.Does it effective?
  14. Caomhin
    Worth a try to see what happens. You will have to backup the phone though. As it will wipe the phone.
    ROLL-BACK FROM CURRENT ANDROID 10 Stable TO EARLIER STOCK ANDROID 9 OR 10
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    Thanks to @ironass for putting this together.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    And here is a seperate guide to bring you straight back to Android 9 if you wish to go that far back.
    https://wccftech.com/how-to/downgrade-android-10-to-android-9-pie-on-oneplus-6t-6-guide/
  15. ASH.win_280
    Donut Sep 26, 2020
  16. Caomhin
    As mentioned 100s of times as a suggestion, and has fixed most charging issues, quick search will find it.
    Clean the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully.
    Auristic, ItsRavi25, rhyd1am and 3 others like this.
  17. mrawat108
    Donut Sep 26, 2020
  18. Abhishek_Singh_2
    Honeycomb Sep 26, 2020
  19. Shshank Vishwa
    Shshank Vishwa , via OnePlus 6 , Sep 26, 2020 :
    As a consumer, after paying for your phone, how can you even think of losing the integrity of your phone by installing custom rom.
    And my post was not about software excitement, android 11 etc.. Its was about how a basic but important security patch is not delivered by the manufacturer which is supposed to be monthly basis.Don't care about the new features, but security.. And installing a custom rom for security update , how can you even suggest that!!
    Do note, the fate will come to ur 50-60K 8 Pro too, in future.
  20. rhyd1am
    Jelly Bean Sep 26, 2020
    rhyd1am , via OnePlus Community App , Sep 26, 2020 :
    Oneplus are really pretty upfront about their security updates. They are released as part of their bi monthly updates.
    Sure security updates are important, but not nearly as important as the users responsibility for their own device.
