321
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Z1553239049735
    Froyo Jul 31, 2020
  2. asgarder
    Cupcake Jul 31, 2020
  3. Caomhin
    Community Hero 2020 Jul 31, 2020
    Caomhin , via OnePlus 6T , Jul 31, 2020 :
    As its just released, I would suggest maybe give it a day or 2 and see how it performs, it is very fluid, and runs smooth, but my 6T did that anyway.
  4. Caomhin
    Z1531379359224 and rHITkM like this.
  5. manasarora98
    Ice Cream Sandwich Jul 31, 2020
    manasarora98 , via OnePlus 6 , Jul 31, 2020 :
    Finally, smooth experience is back on stable build.
    Thanks for the Optimised RAM Management and Fix for Chrome crashes.
    However, no features but I have zero hope now for breakthrough features till the Android 11(R) Update.
    But thankfully, phone at the moment feels much smooth to me after 10.3.3 and 10.3.4 disasters.
    I hope Privacy Alerts and Dual Channel Acceleration from the Open Beta 6(Last Beta for 6 series) make it through in the next stable update.
    Edit : "Handling Theme" notifications I guess fixed too.
  6. asgarder
  7. G_Huynh_Tinh
    Gingerbread Jul 31, 2020
    petertinh and Vkamat1990 like this.
  8. I1548089682366
    Donut Jul 31, 2020
  9. abhijit2610
    Deepak Dkp, Srijan3194 and moricka like this.
  10. manasarora98
    One more thing, GMS Package is updated to May?
    I had already updated it to 1st May 2020 before updating to 10.3.5.
    Also, still it doesn't show any updates yet by Google on GMS.
    Was this a miss at Google side if they haven't given any GMS update since May or OnePlus forgot to add the capability to download the GMS pacakage for June & July which is/should be already rolled out by Google?
  11. Caomhin
    Try the following
    Clear Chrome App info Cache.
    Also open Chrome, go to Settings>Site Settings>Storage click on Clear Site Storage.
    Also clear browsing history in Chrome Settings>Privacy>Clear Browsing Data. Select All Time for the Time Range, then Clear Data.
    See if that helps.
  12. Caomhin
    drl431 and rHITkM like this.
  13. Caomhin
    Clear all your Screen Locks Pins, Fingerprint and Facelocks
    Also clear all the Smart locks as well.
    Reboot and see if you can get into the Bootloader.
    You can setup you screen locks once you get back into OOS.
    See if that helps.
  14. Bony_Oinam
    Bony_Oinam , via OnePlus 6 , Jul 31, 2020 :
    Yes
  15. Caomhin
    GMS and Playstore System Update are seperate entities.
    GMS is updated via a build update, but Playstore System Update can be updated by clicking on the option you see there.
    Check here for more info
    https://www.androidcentral.com/what-gms-and-why-does-my-phone-need-it
    ItsRavi25, Tee_Eee_Bee and rHITkM like this.
  16. R1546794257717
    Donut Jul 31, 2020
    H1587630708152 and Santoshtheone like this.
  17. Caomhin
    I use Oxygen updater, no patience to wait, but when i still receive OTA prompts when I don't bother updating via Oxygen Updater.
    It does not prevent OTA you will still receive updates that way.
  18. Srínívas Sñ
    Honeycomb Jul 31, 2020
    #38
  19. DarkSoul7
    DarkSoul7 , via OnePlus 6T , Jul 31, 2020 :
    Wow i never received updates again after updating from oxygen updater
    #39
    ravi1553272, Sluciani76 and PyresTakk like this.
  20. manasarora98
    Are you able to update on clicking at it for Play System Update?
    Mine shows up to date with 1st May 2020. (however, red)
    I guess GMS and Security Patches were different.
    PlayStore System Update is a subset of GMS as far as I know.
    #40
    Maverick2.0 likes this.
