320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. ItsRavi25
    Jelly Bean Aug 1, 2020
    ItsRavi25 , via OnePlus 6T , Aug 1, 2020 :
    Use oxygen updater for faster update
    OR
    Install the update manually
    Here is the link for incremental OTA... (10.3.5)
    ONEPLUS 6
    https://otafsg1.h2os.com/patch/amaz...gen_22_OTA_046-047_patch_2007191515_f9bd1.zip
    ONEPLUS 6T
    https://otafsg1.h2os.com/patch/amaz..._046-047_patch_2007171912_5566e9d41cbb5d6.zip
    Full OTA
    ONEPLUS 6
    https://otafsg1.h2os.com/patch/amaz...Oxygen_22_OTA_047_all_2007191515_d9e52461.zip
    ONEPLUS 6T
    Backup your all data
    Copy the zip to the root of your internal storage
    Go to Settings > System > System Updates
    Tap the gear icon top right, followed by 'Local upgrade'
    Read the warning and tap confirm
  2. ItsRavi25
    This issue may occur sometime after updating...best solution is to backup your file and rest your device via recovery...
    Lakshyaraj_Singh likes this.
  3. ItsRavi25
    Louie Allen likes this.
  4. Lakshyaraj_Singh
    Eclair Aug 1, 2020
    Lakshyaraj_Singh , Aug 1, 2020 :
    I'll try it, thanks.
  5. devesh darji
    Gingerbread Aug 1, 2020
    devesh darji , via OnePlus 6T , Aug 1, 2020 :
    Update made ui smoother . I always perform play store update and clear cache from recovery after update. So never has small problems due to file overlapping. Good to see updates. Don't expect new features on 6 t from OP.
    VivekBhagat10 likes this.
  6. ItsRavi25
    As mentioned in the first post... it's STAGED ROLLOUT it will take time to roll out globally.
    OR
    ONEPLUS 6
    ONEPLUS 6T
    Full OTA
    ONEPLUS 6
    ONEPLUS 6T
    drl431 and Gowtham_Bharathi like this.
  7. ItsRavi25
    drl431 likes this.
  8. rehannali
    Froyo Aug 1, 2020
    rehannali , via OnePlus 6T , Aug 1, 2020 :
    Hi, did anyone notice if warp charge issue fixed in this update for OP6T McLaren or this is another fixes update which isn't fix anything?
  9. Louie Allen likes this.
  10. Gowtham_Bharathi , via OnePlus 6T Mirror Black , Aug 1, 2020 :
    Thanks Ravi
  11. GOPIBS
    Cupcake Aug 1, 2020
    GOPIBS , Aug 1, 2020 :
    Normally after creating a note it was able to share as a picture or text or can be saved. But now a days I found it unable to share or save the notes created via the options in the app itself. While trying to share or save the notes, the app shows "not responding", "wait or close" like that. I don't have screenshots for this issue. It will be good if a new update with these bugs fixed. Thank you.
  12. GOPIBS
    Cupcake Aug 1, 2020
    Does the slow motion edit option gets back with this update?
    It's very important to edit the slo-mo.
  13. ItsRavi25
    No, it will be there in upcoming Gallery update..
    Use Google photos to edit slow motion videos.
  14. GOPIBS
    Cupcake Aug 1, 2020
  15. disaur
    Cupcake Aug 1, 2020
  16. Kuronosu
  17. V1537591019064
    Eclair Aug 1, 2020
    V1537591019064 , via OnePlus 6 , Aug 1, 2020 :
    Still didn't get any updated, what I will do can update through oxygen updater (is it safe update through oxygen updater) or I will wait for it to update normally ??
