320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 8, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 8, 2020 :
    Did you ever update it manually once? If you uninstall updates of it? If you also clear data on it what happens?
    Did you update any other OS components manually?
    D.Sai Suhail Baba likes this.
  2. Venkateswar@1101
    Eclair Oct 8, 2020
  3. D.Sai Suhail Baba
    Jelly Bean Oct 8, 2020
    Caoimhín likes this.
  4. Venkateswar@1101
    Eclair Oct 8, 2020
  5. Auristic
    Lollipop Oct 8, 2020
    Auristic , Oct 8, 2020 :
    An antivirus on a mobile is useless: YOU are the best antivirus by not installing anything from anywhere.
    Uninstall Kasperski, reboot your mobile and try again to install the dashboard apk.
  6. Srínívas Sñ
    Honeycomb Oct 8, 2020
    Srínívas Sñ , via OnePlus 6 , Oct 8, 2020 :
    Fake software maintenance schedule still no updates for OnePlus 6 device and there is a just 3 series are now running for updates OnePlus 6, 7, 8. the company is unable to handle this just 3 device software updates...
  7. MCunha
    Gingerbread Oct 8, 2020
    MCunha , Oct 8, 2020 :
    Odd... I can't find dashboard installed on my op6...
    And can't install it using the link.
    Is that normal?
    ((show system app is selected)
  8. Caoimhín
    Caoimhín , via OnePlus 6T , Oct 8, 2020 :
    Send your gripe directly to OnePlus. All Users here the same as you, and we are also waiting, but we have patience. 😎👍
    Feedback tool
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  9. D.Sai Suhail Baba
    MCunha and Caoimhín like this.
  10. Caoimhín
    Just tried it myself and it will not install, the versions above the one you have installed already are APK rips from other Phone models and are probably specific to those models.
    I get the same error
    The version for 6 series phones is the one you have installed.
    Same as on my 6T
  11. D.Sai Suhail Baba
    D.Sai Suhail Baba , Oct 8, 2020 :
    Once I have updated it from APKmirror. I think now we can't update dashboard.
  12. I1549642358539
    Eclair Oct 8, 2020
    I1549642358539 , Oct 8, 2020 :
    battery draining @ night on stand by by 10% draining ....
    .I personally disappointed wt op6t .....
  13. Auristic
    Artemus., ItsRavi25, ironass and 3 others like this.
  14. ultkaizoku
    Donut Oct 8, 2020
    ultkaizoku , via OnePlus 6T , Oct 8, 2020 :
    What's the point of this?
    It's absolutely ridiculous that we're still stuck on July security patches. I don't care about new features in updates, but the slow schedule for security patches is absolutely pathetic.
    This is why I'm definitely not buying another OnePlus once I feel I got my money's worth out of my 6T. I'm better off going back to Google phones seeing that everyone's already cheeping out with mid-range SoCs anyway and cameras are already good enough.
    suraj1595 likes this.
  15. D.Sai Suhail Baba
    If you buy or don't buy OnePlus devices it doesn't matter bcz fact is fact when OnePlus preparing for release of new devices they mostly work on software stability for new devices but this time they are releasing more devices so everyone is working on new devices. Currently 8 series and 6 series haven't received update. They may release on launch day or after launch day. Everyone are users in this thread and can't help. If you have any issues report your feedback and issues through feedback section or OnePlus support page in twitter.
    Auristic and Caoimhín like this.
  16. ImtiyazJendi
    Cupcake Oct 8, 2020
    ImtiyazJendi , Oct 8, 2020 :
    My camera's portrait mode is not working can anyone help me please whenever I try to open the main camera in portrait mode the app just crashes please help someone
  17. Caoimhín
    1st make sure you are using 3.8.114 or 3.8.116 which are the versions that work on 6 series phone, if you are using a version with a higher number, go into App info, click on the 3 dot menu and uninstall updates. So it reverts to the 6 series Stock version.
    Also clear the OnePlus Camera App info Cache and App info Storage as well.
    See if that helps.
  18. ImtiyazJendi
    Cupcake Oct 8, 2020
    I am using 3.8.114 version. Thanks for the info will try and revert here
  19. ImtiyazJendi
    Cupcake Oct 8, 2020
    I M using 3.8.114 and there is no Option of uninstalling updates what should I do 2 days before it was working fine recently only I noticed that it is not working and the app keeps on crashing when pressed on Portrait Mode. It would be of great help of u can bail me out of this issue..
  20. Caoimhín
    That's fine, there won't be an option to uninstall if you are already on the stock 3.8.114, just some have installed other versions that won't work properly and I wasn't sure if you had.
    Have to tried the cache clear as I mentioned above.?
    Auristic and ItsRavi25 like this.
