320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. ImtiyazJendi
    Cupcake Oct 8, 2020
    ImtiyazJendi , Oct 8, 2020 :
    Yes sir I have done all things in fact i have factory reset my phone for this problem. Looks like i have to visit a nearest one plus store now
  2. Caoimhín
    OnePlus 9 Series Expert Community Expert Oct 8, 2020
    Caoimhín , via OnePlus 6T , Oct 8, 2020 :
    One more thing to try, is to install a GCam and see if that can use the camera as normal. If it can't then more than likely a hardware issue and you may have to go to an approved OnePlus service center
    I have this one installed and it works very well.
    7.3_GCam_MJL_v4.1.1_Minilux.apk (marco, 2020-04-29, oneplus 6/6t, changelog)
    The XML are integrated, so no additional files required.
    https://www.celsoazevedo.com/files/android/google-camera/dev-marco/
    You can also run a Diagnostic with the OnePlus Diagnostic tool. Have used it myself. Though it shows everything fine so far on my 6T.
    You can run this tool to check if everything is working as expected by clicking on Detect Now.
    Just follow the instructions on the screen.
    Download OnePlus Diagnostic tool.
    https://www.apkmirror.com/apk/oneplus-ltd/oneplus-diagnostic/
  3. mohal
    Ice Cream Sandwich Oct 9, 2020
    D.Sai Suhail Baba likes this.
  4. Daniel Sogor
    Froyo Oct 9, 2020
    Daniel Sogor , via OnePlus 6 , Oct 9, 2020 :
    I have an Xiaomi Mi A2 Lite in family, bought with 150$ new and have new update with security patch and sometimes some improvement's, every months, not like my OnePlus 6 phone, bought with 500$, I get an update every 3 or 4 month... That's shame.
  5. Godfather 1
    Jelly Bean Oct 9, 2020
    Godfather 1 , Oct 9, 2020 :
    You should definitely switch to that phone then.. sounds good to me.
  6. pradip1173 , via OnePlus 6 Mirror Black , Oct 9, 2020 :
    Other smartphone company pushing their update but on oneplus 6,no update since july last week.evrn the security patch is way back to july.no idea ehen we will get to check update on my device.
    Ronesso17 and D.Sai Suhail Baba like this.
  7. Koushik87
    Gingerbread Oct 9, 2020
  8. OnePlus.rksharma
    Honeycomb Oct 9, 2020
    OnePlus.rksharma , via OnePlus 6T , Oct 9, 2020 :
    Mi A2 is part of Android one (Google One series Campaign). that is the Reason of faster updates in Mi A2
  9. OnePlus.rksharma
    Auristic and D.Sai Suhail Baba like this.
  10. OnePlus.rksharma
    See thes.... A2 is Android One line-up device
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 9, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 9, 2020 :
    You mean the cable is expensive compare to other cables?
    From right. Ancient micro USB Samsung orginal. Rated for eh... "crap".
    2nd. Modern S20 line Samsung double ended USB-C cable. Rated for QC 2.0 and looks and practically feels the same as the ancient one.
    3rd. Standard Warp cable. 5V 6A. Thick and sturdy (almost too sturdy).
    4th. Flat Warp cable (the one from the store, more expensive and exclusive than the one that comes with the phone). 5V 6A. More flexible and nicer to handle.
    I consider the 4th to belong to the premium cable class. There are even more premium ones ofcourse (kevlar and braided ones for example... But this is the best for Warp)
    drl431, Auristic and Caoimhín like this.
  12. ImtiyazJendi
    Cupcake Oct 9, 2020
    ImtiyazJendi , Oct 9, 2020 :
    hey hi there have downloaded the Gcam and the portrait mode works fine in that. But the problem still persist with the in build app. Any solution on that?
  13. ImtiyazJendi
    Cupcake Oct 9, 2020
  14. Master_TC
    Master_TC , Oct 9, 2020 :
    Force stop of the app. Clear cache and data of the app and then reboot phone. Now it should work.
  15. ImtiyazJendi
    Cupcake Oct 9, 2020
    Have done everything + even have factory reset the phone sire.
  16. Master_TC
  17. ImtiyazJendi
    Cupcake Oct 9, 2020
  18. S1569822702212
    Cupcake Oct 9, 2020
  19. Caoimhín
    Caoimhín , via OnePlus 6T , Oct 9, 2020 :
    If its working in the GCam but not in OnePlus Camera, sounds like a possible corruption somewhere between the Camera and Android.
    There are 3 different reset options. Try the full Erase option as per the steps below. Make sure you Enable Erase Internal Storage, so you are starting completely fresh.
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    ⚠️Enable Erase Internal Storage⚠️
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    Auristic, ItsRavi25 and drl431 like this.
  20. Sanky8990
    Froyo Oct 9, 2020
