320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Robert Chris
    Donut Aug 1, 2020
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 1, 2020
    Caomhin , via OnePlus 6T , Aug 1, 2020 :
    With so little info to go on, try the following.
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Once done, use the phone for a couple of days without adding apps to check for issues with just the raw fresh OOS only.
    Only introduce previous 3rd party apps gradually over 2 weeks to see if any particular app or apps drain the battery
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    OP6T Battery and Heating Thread
    https://forums.oneplus.com/threads/unified-op6t-battery-and-heating-thread.952987/
    drl431, rHITkM and rhyd1am like this.
  3. Caomhin
    Yes, you will still get future OTA, its just an alternative way to get the update sooner.
    drl431, rhyd1am and P8505893412 like this.
  4. P8505893412
    Eclair Aug 1, 2020
    P8505893412 , via OnePlus 6 , Aug 1, 2020 :
    Ohh that sound good then😀..thankyou ..!![e]1f44d[/e]
    Caoimhín likes this.
  5. stratoc
    Eclair Aug 1, 2020
    stratoc , via OnePlus 6T , Aug 1, 2020 :
    This upgrade actually makes me think I have a new phone.
    Zero lag
    Zero theme notification.
    Really great upgrade.
    Possibly the best I have had on 6t
  6. T1562951520933
    Cupcake Aug 1, 2020
    T1562951520933 , via OnePlus 6T , Aug 1, 2020 :
    Instagram app is not working in my phone. All other apps work properly but Instagram works only for few minutes after reinstalling. Can you please fix the bug?
  7. Caomhin
    Revert to a previous version of Instagram, this sometimes fixes such issues.
    Turn off Auto update in the Playstore.
    Backup anything you require from Instagram Uninstall current Instagram version.
    Try this Stable version from earlier in July.
    https://www.apkmirror.com/apk/insta...tagram-150-0-0-33-120-7-android-apk-download/
    If this fixes the issues, then it's Instagram issues with more recent updates, which happens a lot. Need to talk to Instagram developers about this.
    drl431 and ItsRavi25 like this.
  8. sumitMZ007
    Jelly Bean Aug 1, 2020
    sumitMZ007 , via OnePlus 6 , Aug 1, 2020 :
    Sorry to say I tried your method but it's not working for me..still it's giving 40% charge in 30min.. earlier my phone used to charge 3% per minute..these updates has ruined it..
  9. Caomhin
    Normally fast charge will take up to an hour, quick to 80%, then it slows for the last 20%.
    Thisnis also something to try, people get mixed results from this, but it may work for you. Just be careful when selecting the cache to delete. Follow the steps to the letter.
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    rHITkM and ItsRavi25 like this.
  10. wmbaak
    Donut Aug 1, 2020
    wmbaak , Aug 1, 2020 :
    Thank you for the update. Especially for the crash of Chrome. I thought it was a bug of Chrome.
  11. Caomhin
    rHITkM, wmbaak and rhyd1am like this.
  12. rhyd1am
    KitKat Aug 1, 2020
    rhyd1am , via OnePlus 6T , Aug 1, 2020 :
    Just for info, Instagram didn't work on my device either after the update, however it is working fine for me now. Haven't done anything with the app itself, so I can only assume that it was rebooting my phone that has got it working.
    drl431 and Caoimhín like this.
  13. V1537591019064
    Eclair Aug 1, 2020
  14. Caomhin
    V1537591019064
    Updating through oxygen updater, it's not showing update features and Google Play system didn't update to July 1
    And GOOGLE Play System Update, updates seperately to GMS update that was included, down to Google as to when they update that.
    That's right, it never does. But if you open Oxygen Updater, it will show at the bottom of the screen
    Select View Update Information from the bottom of the screen.
    ItsRavi25 and V1537591019064 like this.
  15. V1537591019064
    Eclair Aug 1, 2020
  16. V1537591019064
    Eclair Aug 1, 2020
    V1537591019064 , via OnePlus 6 , Aug 1, 2020 :
    But how some people get its July 1 st
  17. Caomhin
    They have a random Rollout, haven't received it myself either, no idea what they use for criteria to roll it out. Google just do their own thing.
    ItsRavi25, ironass and V1537591019064 like this.
  18. V1537591019064
    Eclair Aug 1, 2020
    Ok thank you
  19. Caomhin
    Never, this is 6 series thread
  20. adibahmad786@gma
    Cupcake Aug 1, 2020
