180
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Balaji6t
    Gingerbread Aug 1, 2020 at 5:27 PM
  2. Eduardo_Alexandre_Eloi
    Cupcake Aug 1, 2020 at 5:27 PM
    Eduardo_Alexandre_Eloi , Aug 1, 2020 at 5:27 PM :
    I blocked the bootloader. But the update continues to fail when it reaches 72%
  3. Eduardo_Alexandre_Eloi
    Cupcake Aug 1, 2020 at 5:28 PM
  4. Balaji6t
    Gingerbread Aug 1, 2020 at 5:29 PM
  5. Kuronosu
    Froyo Aug 1, 2020 at 5:30 PM
    Kuronosu , Aug 1, 2020 at 5:30 PM :
    To everyone: JUST WAIT until the full update zip for the 6T is available.
    JUST.
    WAIT.
    The full zip for the 6 is already available.
  6. Eduardo_Alexandre_Eloi
    Cupcake Aug 1, 2020 at 5:31 PM
    Eduardo_Alexandre_Eloi , Aug 1, 2020 at 5:31 PM :
    is not working for me, the error in installing the update when it reaches 72%
  7. Gokul7373
    Gingerbread Aug 1, 2020 at 5:41 PM
    Gokul7373 , via OnePlus 6T , Aug 1, 2020 at 5:41 PM :
    Bro.....i am using midnight Black 😅😅
    Balaji6t likes this.
  8. Gokul7373
    Gingerbread Aug 1, 2020 at 5:46 PM
  9. rHITkM
    Honeycomb Aug 1, 2020 at 5:47 PM
    zayn_ys, Caomhin and Alessandro_R. like this.
  10. Gokul7373
    Gingerbread Aug 1, 2020 at 5:47 PM
    rHITkM and Balaji6t like this.
  11. rhyd1am
    Jelly Bean Aug 1, 2020 at 5:55 PM
    Caomhin and rHITkM like this.
  12. rHITkM
    Honeycomb Aug 1, 2020 at 5:57 PM
    rHITkM , Aug 1, 2020 at 5:57 PM :
    let me be clear I am not against any language, and Yes, english is mandatory here, forum rules. If you want to discuss with someone who knows the same language as you than you can message them privately. [e]1f64f[/e][e]1f44d[/e]
    zayn_ys, kjjm and Caomhin like this.
  13. rHITkM
    Honeycomb Aug 1, 2020 at 5:58 PM
    Caomhin and rhyd1am like this.
  14. V1547695374711
    Cupcake Aug 1, 2020 at 5:59 PM
  15. Caomhin
    Lollipop Aug 1, 2020 at 6:00 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 6:00 PM :
    Yes it will wipe the phone. Its either that or wait for the full release to install this update.
  16. Eduardo_Alexandre_Eloi
    Cupcake Aug 1, 2020 at 6:02 PM
    Eduardo_Alexandre_Eloi , Aug 1, 2020 at 6:02 PM :
    I blocked the bootloader, but the error still fails when it reaches 72%, the way to wait for the complete update
  17. Caomhin
    Lollipop Aug 1, 2020 at 6:02 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 6:02 PM :
    As per first post top of the thread
    rhyd1am likes this.
  18. rhyd1am
    Jelly Bean Aug 1, 2020 at 6:03 PM
    rhyd1am , via OnePlus 6T , Aug 1, 2020 at 6:03 PM :
    You can either wait for the OTA for 10.3.5 (which includes security patch). Or you can download the update and install it manually via local upgrade.
    Incremental update OnePlus 6
    https://otafsg1.h2os.com/patch/amaz...gen_22_OTA_046-047_patch_2007191515_f9bd1.zip
    Full update Oneplus 6
    https://otafsg1.h2os.com/patch/amaz...Oxygen_22_OTA_047_all_2007191515_d9e52461.zip
    Incremental update Oneplus 6T
    https://otafsg1.h2os.com/patch/amaz..._046-047_patch_2007171912_5566e9d41cbb5d6.zip
    Or alternatively you can download the 3rd party "Oxygen Updater" ago from the playstore.
    V1547695374711 and Caomhin like this.
  19. Gowtham_Bharathi
    Donut Aug 1, 2020 at 6:03 PM
    Caomhin likes this.
  20. Caomhin
    Lollipop Aug 1, 2020 at 6:06 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 6:06 PM :
    If you are already on 10.3.4 and you have relocked the Bootloader correctly and it is still failing then there is a fundamental issue with your OS.
    Couple of questions.
    Is the phone a T Mobile carrier phone.?
    Are You sure the Bootloader is locked.?
    Were there any other modifications done when the Bootloader was unlocked?
    You may have to reset your phone again. Backup your data. Do a full Erase All Data factory reset again. As something is not operating correctly.
    ItsRavi25 and rhyd1am like this.
  21. J1559717809662
    Cupcake Aug 1, 2020 at 6:07 PM
    J1559717809662 , Aug 1, 2020 at 6:07 PM :
    Oneplus is simply bullshit, I've updated my phone and each and every new update I thought that bug will fixed but problem which I'm facing from 2 years, I can't use android auto and many other bugs, I'm going to sue OnePlus soon.
  22. Caomhin
    Lollipop Aug 1, 2020 at 6:07 PM
  23. Caomhin
    Lollipop Aug 1, 2020 at 6:11 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 6:11 PM :
    J1559717809662
    Oneplus is simply bullshit, I've updated my phone and each and every new update I thought that bug will fixed but problem which I'm facing from 2 years, I can't use android auto and many other bugs, I'm going to sue OnePlus soon.​
    I doubt a lawsuit will work, as Android Auto has its own issues possibly causing this.
    OnePlus provide you a phone to use as is designed which it is doing.
    Connection to another manufacturers software and device is not their concern. That's down to others to make their receiver compatible.
    You may need to contact your vehicle manufacturer and the Google Auto developers as well to see what they can do.
    However here is one suggestion to try.
    https://oneplustips.com/fix-android-auto/
    Also its happening on many manufacturers phones, its a common problem with Android Auto.
    https://www.google.com/search?q=can...&client=ms-unknown&sourceid=chrome-mobile&ie=UTF-8
