180
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. ShahPpArth
    Cupcake Aug 1, 2020 at 6:12 PM
  2. J1559717809662
    Cupcake Aug 1, 2020 at 6:13 PM
    J1559717809662 , Aug 1, 2020 at 6:13 PM :
    I've tried another phones and connected to my vehicle, it works fine only problem which I'm facing is with only OnePlus 6t, even I've tried with OnePlus 7 it works fine.
  3. vermasidd7
    vermasidd7 , Aug 1, 2020 at 6:13 PM :
    Sometime when WhatsApp notification or Instagram notification popped up then suddenly for a couple of second my device get hanged, this problem is with me from last couple of months.
  4. rhyd1am
    Jelly Bean Aug 1, 2020 at 6:13 PM
    rhyd1am , via OnePlus 6T , Aug 1, 2020 at 6:13 PM :
    And during those 2 years what have you tried to get the issues resolved? Have you provided feedback using the feedback tool
    https://forums.oneplus.com/feedback
    drl431 and Caomhin like this.
  5. Caomhin
    Lollipop Aug 1, 2020 at 6:14 PM
    Caomhin , via OnePlus 6T , Aug 1, 2020 at 6:14 PM :
    I have update the post.
  6. Caomhin
    Lollipop Aug 1, 2020 at 6:15 PM
    rhyd1am likes this.
  7. Caomhin
    Lollipop Aug 1, 2020 at 6:16 PM
    rhyd1am likes this.
  8. Promil Kumar
    Donut Aug 1, 2020 at 6:17 PM
    Promil Kumar , via OnePlus 6T Midnight Black , Aug 1, 2020 at 6:17 PM :
    No one can update from oxygen updater app!!! The file can only be downloaded and then you sideload and upgrade the system via settings only
  9. rhyd1am
    Jelly Bean Aug 1, 2020 at 6:18 PM
    rhyd1am , via OnePlus 6T , Aug 1, 2020 at 6:18 PM :
    I do believe you're both lost, this is the 6 series thread! The 7 and 7t series threads are the next exit 🙄
    drl431 and rHITkM like this.
  10. Eduardo_Alexandre_Eloi
    Cupcake Aug 1, 2020 at 6:19 PM
    Eduardo_Alexandre_Eloi , Aug 1, 2020 at 6:19 PM :
    I remade everything you just told me, they are in the latest stable version OS 10.3.4. My phone is not from T Mobile, I'm sure it was blocked, until the message that appears on the bootloader startup that was unlocked suniu, I did the check by restarting it on fastboot, and showed that it is blocked,
    when it was unlocked it had root on it, nothing more than that, but I had unroot it for a long time, I only had the bootloader unlocked just that, I didn’t make any other changes to it, I formatted it 2x already
  11. Kuronosu
    Froyo Aug 1, 2020 at 6:22 PM
    disaur likes this.
  12. V1547695374711
    Cupcake Aug 1, 2020 at 6:22 PM
    V1547695374711 , via OnePlus 6T , Aug 1, 2020 at 6:22 PM :
    I have a doubt,the file was download,will go to local upgrade ok,when I'm install file,i don't loss phone data or not
  13. G1541799549854
    Cupcake Aug 1, 2020 at 6:23 PM
    G1541799549854 , via OnePlus 6T , Aug 1, 2020 at 6:23 PM :
    Yes you will get official ota updates.
  14. W1541215576093
  15. V1542355418709
    Cupcake Aug 1, 2020 at 6:25 PM
  16. P_Chandra_Sekhar_swamy
    Cupcake Aug 1, 2020 at 6:27 PM
    P_Chandra_Sekhar_swamy , via OnePlus 6 , Aug 1, 2020 at 6:27 PM :
    I was in beta build. I have to update this manually???
  17. rhyd1am
    Jelly Bean Aug 1, 2020 at 6:29 PM
    rhyd1am , via OnePlus 6T , Aug 1, 2020 at 6:29 PM :
    Always a good idea to make regular backups just incase.
    To answer your question though. No, a local upgrade shouldn't cause data loss
  18. rhyd1am
    Jelly Bean Aug 1, 2020 at 6:30 PM
    Caomhin likes this.
  19. V1547695374711
    Cupcake Aug 1, 2020 at 6:31 PM
    rhyd1am likes this.
  20. Myownoneplus6T
    Gingerbread Aug 1, 2020 at 6:33 PM
