180
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. DigitalSachin
    Cupcake Aug 2, 2020 at 6:08 AM
  2. cozzmat
    Ice Cream Sandwich Aug 2, 2020 at 6:15 AM
    cozzmat , via OnePlus 6 Midnight Black , Aug 2, 2020 at 6:15 AM :
    absolutely yes. the only difference is that when you update the device through that tool you will not have the report of what has been updated in the system settings section!
  3. Srínívas Sñ
    Honeycomb Aug 2, 2020 at 6:16 AM
  4. Dbdude10
    Cupcake Aug 2, 2020 at 6:26 AM
  5. GaneshKunte
    Cupcake Aug 2, 2020 at 6:41 AM
  6. R1539270374282
    Cupcake Aug 2, 2020 at 6:42 AM
    R1539270374282 , Aug 2, 2020 at 6:42 AM :
    Hi All,
    I have updated via To Oxygen updater App, the UI was smooth experience but facing few problems
    - Google photos app getting crashed
    - Screenshots not getting saved
    - Media files are not visible in any of my media player though I have to go select manually from my storage to play the videos always
    Anyone face these issues post this new update.
    Thanks
  7. mohal
    Honeycomb Aug 2, 2020 at 6:53 AM
  8. mohal
    Honeycomb Aug 2, 2020 at 6:55 AM
  9. drl431
    Marshmallow Aug 2, 2020 at 7:06 AM
    drl431 , Aug 2, 2020 at 7:06 AM :
    Hi, guessing you were a beta tester. Go back to page 37, post 726. The 5 steps are usually required when going from beta to stable without a system wipe.
    Caomhin likes this.
  10. S1541767555421
    Eclair Aug 2, 2020 at 7:09 AM
    Caomhin likes this.
  11. A1550387522048
    Gingerbread Aug 2, 2020 at 7:24 AM
  12. Reetej Kumar khadka
    Gingerbread Aug 2, 2020 at 7:32 AM
  13. Yuvraj6592
    Donut Aug 2, 2020 at 7:37 AM
  14. hemnathad
    Eclair Aug 2, 2020 at 7:42 AM
  15. I1548089682366
    Donut Aug 2, 2020 at 7:42 AM
    I1548089682366 , Aug 2, 2020 at 7:42 AM :
    Almost everything works fine in this update. good battery backup and smooth performance.but i have only one issue. while making notes in memo, to set the alarm in notes the position of calendar and clock is slightly above the screen. I have faced the same problem in previous build also. In this update also it is not fixed but alarm of notes works fine.
  16. echelon9797
    Froyo Aug 2, 2020 at 7:48 AM
    echelon9797 , via OnePlus 6T , Aug 2, 2020 at 7:48 AM :
    DC dimming is always off, and I'm on the latest OnePlus launcher version as well. Ive tried restarting the phone but to no avail. This issue is there since OOS 10.3.3
    rHITkM likes this.
  17. U1579421963397
    Cupcake Aug 2, 2020 at 7:56 AM
  18. Tee_Eee_Bee
    Honeycomb Aug 2, 2020 at 7:58 AM
    Tee_Eee_Bee , via OnePlus 8 Pro , Aug 2, 2020 at 7:58 AM :
    hemnathad
    Can i upgrade from open beta 6 to 10.3.5, without losing any data​
    You should be able to upgrade as 10.3.5 has a newer build date.
    Having said that, it's always good practice to have a backup of your data just in case something goes wrong.
    Caomhin, rHITkM and rhyd1am like this.
  19. Tee_Eee_Bee
    Honeycomb Aug 2, 2020 at 8:03 AM
    Caomhin, rHITkM and mohal like this.
  20. D.Sai Suhail Baba
    Gingerbread Aug 2, 2020 at 8:04 AM
    D.Sai Suhail Baba , Aug 2, 2020 at 8:04 AM :
    Because currently both 8 series and 6 series don't have beta builds currently both series only have closed beta builds (included some developers and selected users) and stable builds.
    rHITkM and Tanmay S like this.
