320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Ericb3800
    Donut Aug 4, 2020
    Ericb3800 , Aug 4, 2020 :
    https://forums.oneplus.com/threads/fast-charging-not-working-on-os-10-3-4.1241289/
  2. Ericb3800
    Donut Aug 4, 2020
    https://forums.oneplus.com/threads/oneplus-6-charging-problem-in-android-10.1158917/
  3. Ericb3800
    Donut Aug 4, 2020
    Plus many op7 complaints as well
  4. VikramMohal
    Ice Cream Sandwich Aug 4, 2020
    mitheshge likes this.
  5. OnePlusSQRT36
    Gingerbread Aug 4, 2020
    OnePlusSQRT36 , via OnePlus 6 , Aug 4, 2020 :
    Pixel put on the heat with 4a.....I am shopping as am been disappointed in the op6 updates to date. I am not going Samsung for sure so will be a toss up between op8 and pixel
  6. rHITkM.
    rHITkM. , Aug 4, 2020 :
    I had similar issue with my Sony Xperia Z5, actualy the problem was with charger cause I was unable to recreate the issue with another charger.
    Conclusion:- It seems to be related to the charger or cable.
    See if other charger are working fine with the device. If it does work the you have faulty charger or charging cable
    Reason :- might be the Surge in electicity voltage.
    Caoimhín likes this.
  7. Ericb3800
    Donut Aug 4, 2020
    thanks. been there. read that
    rHITkM likes this.
  8. rHITkM.
    Great, so check to see what causing the problem the charger or the cable
    Let me know if this was helpful [e]1f64f[/e]
    Caoimhín and zayn_ys like this.
  9. Ericb3800
    Donut Aug 4, 2020
    new cable and charger. still no love
  10. ramkr1607
  11. Bowery_King
    Froyo Aug 4, 2020
    mohal and Caoimhín like this.
  12. DS_chakri
    Froyo Aug 4, 2020
    DS_chakri , via OnePlus 6 , Aug 4, 2020 :
    Guys, How is the camera performance after the update?
    Hows the color calibration, is there any visible changes in display screen calibration??
  13. A1560734135095
    Eclair Aug 4, 2020
    A1560734135095 , via OnePlus 6T , Aug 4, 2020 :
    No, I never received official update after updating through oxygen updater
  14. A1560734135095
    Eclair Aug 4, 2020
  15. G1596512221295
    Cupcake Aug 4, 2020
    Reetej Kumar khadka likes this.
  16. zayn_ys
    zayn_ys , via OnePlus 6T Thunder Purple , Aug 4, 2020 :
    It's just a myth, you'll receive the updates even after updating through Oxygen updater. Well, it just depends on your patience as the updates are staged roll outs. It takes time to reach on your phone. If you want to update early then use Oxygen updater or if you can wait then the update will come to your phone someday.
  17. zayn_ys
    No issues after the update. If you're talking about the color shifting while unlocking the phone then it's present on everyone's device. Not sure if it's a bug or an animation.
    If you're facing the color shifting issue somewhere else then try a factory reset. Take a backup before you do it. See if this helps. If it happens again then you might need to visit a service center.
    mik29194, rHITkM, Caoimhín and 3 others like this.
  18. C1542526158633
    Eclair Aug 4, 2020
  19. mr.daniee
    Cupcake Aug 4, 2020
  20. zayn_ys
