320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. O1534003524594
    Cupcake Aug 4, 2020
  2. zayn_ys
    Ice Cream Sandwich Aug 4, 2020
  3. zayn_ys
  4. Max.Mar
    Jelly Bean Aug 4, 2020
    Max.Mar , Aug 4, 2020 :
    Camera is more or less same..i don't use it anyway. Try Gcam!
    Screen calibration is also not as good as it was on Pie but yes some improvement there.
    D Sai Chakri likes this.
  5. B_Wrath
    Nougat Aug 4, 2020
    B_Wrath , Aug 4, 2020 :
    Please don't give wrong information if you don't know.
    Even if updated via Oxygen Updater, you'll get OTAs.
    kjjm, drl431, rHITkM and 2 others like this.
  6. Q1577338760872
    Cupcake Aug 4, 2020
  7. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Aug 4, 2020 :
    STAGED ROLLOUT mentioned in the first post
    Use oxygen updater for faster update
    OR
    Install the update manually
    Here is the link for incremental OTA... (10.3.5)
    ONEPLUS 6
    https://otafsg1.h2os.com/patch/amaz...gen_22_OTA_046-047_patch_2007191515_f9bd1.zip
    ONEPLUS 6T
    https://otafsg1.h2os.com/patch/amaz..._046-047_patch_2007171912_5566e9d41cbb5d6.zip
    Full OTA
    ONEPLUS 6
    https://otafsg1.h2os.com/patch/amaz...Oxygen_22_OTA_047_all_2007191515_d9e52461.zip
    Backup your all data
    Copy the zip to the root of your internal storage
    Go to Settings > System > System Updates
    Tap the gear icon top right, followed by 'Local upgrade'
    Read the warning and tap confirm
    Caomhin likes this.
  8. Koushik87
    Gingerbread Aug 4, 2020
    Koushik87 , via OnePlus 6T , Aug 4, 2020 :
    The battery life has improved over 10.3.4 in the new version but i observed idle drain is more than active drain. The previous version has less idle drain. I lost around 8 to 9 % overnight with all data, wifi, bluetooth, nfc off. Any one observed the same or is it just me.
    T1560869677284 likes this.
  9. SandeshChinchapur
    SandeshChinchapur , via OnePlus 7 , Aug 4, 2020 :
    Give it some time.
    Caomhin likes this.
  10. T1531394569589
    Eclair Aug 4, 2020
  11. D.Sai Suhail Baba
    D.Sai Suhail Baba , Aug 4, 2020 :
    You have to wait until August 10 because Chinese Software Hydrogen OS will receive Android 11 on August 10.
  12. L1536346915672
    Cupcake Aug 4, 2020
  13. rhyd1am
    rhyd1am , via OnePlus 6T , Aug 4, 2020 :
    You can either wait for the OTA for 10.3.5 (which includes security patch). Or you can download the update and install it manually via local upgrade.
    Incremental update OnePlus 6
    Full update Oneplus 6
    Incremental update Oneplus 6T
    Or alternatively you can download the 3rd party "Oxygen Updater" ago from the playstore.
    rHITkM and Caomhin like this.
  14. harish0601
    Cupcake Aug 4, 2020
  15. Ayushsharma13096
    Cupcake Aug 4, 2020
  16. adi1001
    Honeycomb Aug 4, 2020
    adi1001 , via OnePlus 6T , Aug 4, 2020 :
    It will reach ur device ....be patient....its a staged rollout to minimise the major bugs.
  17. Kafi.bd
    Froyo Aug 4, 2020
    Kafi.bd , via OnePlus 6 , Aug 4, 2020 :
    thanks a lot Caomhin
    Caomhin likes this.
  18. D.Sai Suhail Baba
    Clear cache of Play Store
    Settings > Apps & notification > See all apps > search Google Play Store > open app info > storage & cache > clear cache.
    Caomhin and zayn_ys like this.
  19. zayn_ys
  20. iompatel
    Cupcake Aug 4, 2020
