320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. rajesh9010
    Froyo Aug 4, 2020
  2. VivekBhagat10
    Donut Aug 4, 2020
    VivekBhagat10 , via OnePlus 6T , Aug 4, 2020 :
    Review
    Battery has been improved a lot from last update
    Also it's smooth af
    There is no new features added just. Forget it till OOS 11 next year
    I did faced lags but that was very times(tbh it's better than 10.3.4)
    Camera stills sucks[e]1f602[/e][e]1f602[/e] they have just update camera version
    Also. Ram management has improved it was not a hoax lol.
    Peace
    Just update it i used oxygen os updater
  3. JCCarlos
    Froyo Aug 4, 2020
  4. rHITkM.
    Honeycomb Aug 4, 2020
    rHITkM. , Aug 4, 2020 :
    Oneplus doesn't provide ETA for OTA update. And Because its a staged rollout, everyone will get it in a week or 2 .
    Caomhin likes this.
  5. JCCarlos
    Froyo Aug 4, 2020
    rHITkM likes this.
  6. Caomhin
    Marshmallow Aug 4, 2020
    Caomhin , via OnePlus 6T , Aug 4, 2020 :
    As I said I don't experience your issue at all, and I use WhatsApp extensively. So I find the support for the older 6T fine.
    I did suggest other steps there, but its up to you.
  7. Caomhin
    As your phone is configured personally for yourself, it's an impossible answer to give, everyone will have different experiences, read through the threads. Some get better battery, others not so much.
    It all depends on how you use your phone. No 2 phones will ever be alike once they have been personalised by the user.
    Try it and see.
    Works great on mine, but for every 10 greats you might get one not so great.
    Only you can try it and tell us how it works out on your phone.
  8. kaihp
    Jelly Bean Aug 4, 2020
    kaihp , Aug 4, 2020 :
    :confused: Inconceivable! :D
    ironass, rhyd1am and Caomhin like this.
  9. Caomhin
    OnePlus prepares Android 11 Open Beta as final OxygenOS 11 preview build approaches
    Android 11 is set to make its debut on Pixel devices in just a few weeks, and after that, we’ll be waiting on OEMs to perform the same update on their own handsets. Today, OnePlus has confirmed it will be launching the final OxygenOS 11 developer preview next week with the Android 11 open beta coming soon.
    https://9to5google.com/2020/08/04/oneplus-android-11-open-beta/
    So all 8 series first, then roll down from there to OP6 series, maybe Q2 next year, maybe sooner who knows
    😎[e]1f44d[/e]
    drl431, rHITkM, zayn_ys and 1 other person like this.
  10. meetSky
    Froyo Aug 4, 2020
    meetSky , via OnePlus 6 , Aug 4, 2020 :
    Yes My phone is also getting heat up.
  11. T1594984449950
    Cupcake Aug 4, 2020
  12. V1570780908040
    Donut Aug 4, 2020
    V1570780908040 , via OnePlus 6T , Aug 4, 2020 :
    Yes, I understand.
    Caomhin likes this.
  13. Cervantes
    Lollipop Moderator Aug 4, 2020
    Cervantes , Aug 4, 2020 :
    Hi
    what version did you have before updating
    drl431 and Caomhin like this.
  14. T1594984449950
    Cupcake Aug 4, 2020
    T1594984449950 , via OnePlus 6T , Aug 4, 2020 :
    I have updated latest version .. but after seen here ..
    I didn't get any response through phone ..
    When I check there it's always show your system up to date..
  15. rhyd1am
    rhyd1am , via OnePlus 6T , Aug 4, 2020 :
    As it says at the top of every update thread
    "This OTA will have a staged rollout. The OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs. Using VPN to download this build might not work as the rollout Is not based on regions and is randomly pushed out to a limited number of"
    All updates with OnePlus are rolled out in this way.
    rHITkM and Caomhin like this.
  16. Caomhin
    Fine on mine, no issues, but then it was fine before this update.
    D.Sai Suhail Baba likes this.
  17. Caomhin
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️If it is still heating, try the steps below and then repeat the steps above.[e]2b06[/e]️[e]2b06[/e]️[e]2b06[/e]️
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Once done, use the phone for a couple of days without adding apps to check for issues with just the raw fresh OOS only.
    Only introduce previous 3rd party apps gradually over 2 weeks to see if any particular app or apps drain the battery
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
  18. Antoine L
    Gingerbread Aug 4, 2020
