321
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Oil Junkie
    Cupcake Aug 6, 2020
    Oil Junkie , Aug 6, 2020 :
    Appreciate it ItsRavi25 will check it and get back with the results. Thank you.
    ItsRavi25 likes this.
  2. ironass
    Lollipop Aug 6, 2020
    ironass , Aug 6, 2020 :
    Download and flash the latest firmware in Local Upgrade. I would recommend a clean install.
    rHITkM, Auristic, drl431 and 2 others like this.
  3. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 6, 2020
    Caomhin , via OnePlus 6T , Aug 6, 2020 :
    As per first post top of the thread
    Or you can check the posts above from the last 2 days and install manually via the links given or use other options given.
  4. ItsRavi25
    Jelly Bean Aug 6, 2020
    drl431 and Caoimhín like this.
  5. Caomhin
    Vivektiwari5568
    Clean install?? But how..
    Just through me latest firmware link​
    Check @ItsRavi25 links in post #1454 further up the thread for direct links to manually install 10.3.5
    You can download the Full install file and manually install it over Beta 35, generally without data loss.
    But it's always good practice to Backup your phone first.
  6. Miguel Quezada
    Miguel Quezada , Aug 6, 2020 :
    Just do like you did to get in the beta...
    Auristic, ironass and Caoimhín like this.
  7. Caomhin
    Vivektiwari5568
    It doesn't work​
    Did you move the File to the root main storage on the phone. Not into a folder.
    Also is it the Full file and Not the incremental one.
    Lastly make sure that you remove the .jar at the end of the file if it is there. The file should end in .zip
  8. X1596395895816
    Cupcake Aug 6, 2020
  9. ritik27
    Froyo Aug 6, 2020
  10. Pradishkar15
    Cupcake Aug 6, 2020
  11. Pradishkar15
    Cupcake Aug 6, 2020
  12. i_am_JSK
    Gingerbread Aug 6, 2020
  13. Auristic
    rHITkM, rhyd1am, drl431 and 2 others like this.
  14. Hamza Fayyaz
    Donut Aug 6, 2020
    Hamza Fayyaz , Aug 6, 2020 :
    I've done worst mistake of updating from android 9 to 10(Oxygen os 10.3.5) and now My mobile can't dash charge I cannot connect it to my pc unless I restart several times and OTG is also not working. WTH why can't you guys fix these issue before making our lives a mess. I can't even backup my data so I can flash it back with android 9
    V1537591019064 likes this.
  15. Panky3004
    Eclair Aug 6, 2020
    Panky3004 , Aug 6, 2020 :
    any updates on battery heating? while charging the battery is getting too hot
  16. G1541894604724
    Donut Aug 6, 2020
    G1541894604724 , via OnePlus 6T , Aug 6, 2020 :
    Don't know what is the use of lock box when everything inside of it is accessible and visible from OnePlus file manager without unlocking the Lockbox.....
  17. mohammed_220404
    mohammed_220404 , via OnePlus 7T , Aug 6, 2020 :
    Hey ...currently i am using the OnePlus 7t ...and have the oxygen os open beta 6....and i want to revert back to 10.3.3. HD65AA OR 10.3.4 HD65AA ..BUT CANNOT so can u sya me how did u revert back from beta to stable
