321
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Q1512804799519
    Cupcake Aug 6, 2020
  2. ramkr1607
    Gingerbread Aug 6, 2020
  3. Hima_Sumanth
    Cupcake Aug 6, 2020
    Hima_Sumanth , via OnePlus 6T , Aug 6, 2020 :
    🤷[e]1f612[/e] OnePlus 6t is 1year old than S10 bro.....S10 launched in 2019 ,it's recent phone but 6t is in 2018
  4. Cortexmind
    Cupcake Aug 6, 2020
    Cortexmind , Aug 6, 2020 :
    I joined OnePlus a short time after the startup. After getting an invitation to buy OnePlus One, I had to drive 700 km on my motorbike to another country for meeting the DHL car for a pickup. Rainy and windy it was. After opening the package all was forgotten. In love since then. OnePlus has never disappointed me. I had the 7Pro and is now on 6, waiting for buying one of the next top models. I hope it will be in the spirit of the One.
    I am on update 10.3.4 now and is wondering when or if I will receive update 10.3.5.
    Keep up your good work OnePlus. Never forget your roots.
    Andre_Borges likes this.
  5. SagarLokhande
    Cupcake Aug 6, 2020
  6. SagarLokhande
    Cupcake Aug 6, 2020
  7. ItsRavi25
    Jelly Bean Aug 6, 2020
    ItsRavi25 , via OnePlus 6T , Aug 6, 2020 :
    For battery draining issue try this.
    You can calibrate to enhance your battery life
    For battery draining you should follow this to calibrate..
    Goto settings >App and notifications>Click on three dot in right corner>Reset app preference.
    To Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Thanks to @Caomhin 😇...
  8. G_mahen_sam_Zdas
  9. rhyd1am
    KitKat Community Expert Aug 6, 2020
    rhyd1am , via OnePlus Community App , Aug 6, 2020 :
    What version are you on currently? And what version are you trying to downgrade to?
    You can't simply downgrade the OS version by downloading the file and installing it.
  10. rhyd1am
    That is a perfect example as to why you should always make regular backups. You can't blame the update for your own lack of preparation. That is the nature of software updates, sometimes things happen (which is why you should always backup your data)!
    rHITkM, drl431, Caoimhín and 2 others like this.
  11. T1539496809178
    T1539496809178 , Aug 6, 2020 :
    Till now has anyone experienced that random freezing bug which used to go away whn locking and unlocking the phone in one plus 6?? Till 10.3.4 it existed...in 10.3.5 i wanna know whethee it has been removed or not
  12. mohammed_220404
  13. rhyd1am
    rhyd1am , via OnePlus 6T , Aug 6, 2020 :
    Only just noticed you're using a 7T. If you need to roll back you need to ask in the correct thread.
  14. SagarLokhande
    Cupcake Aug 6, 2020
    SagarLokhande , Aug 6, 2020 :
    Thanks Ravi...!
    ItsRavi25 likes this.
  15. Rhitivik_Ravi
    Cupcake Aug 6, 2020
  16. Deepakdkp
    Honeycomb Aug 6, 2020
  17. rhyd1am
    Deepak Dkp
    Google Play system updated ? How?​
    Because Google Play system updates are pushed out by Google themselves (randomly to devices).
    Or you can check for an update yourself by clicking on it.
    rHITkM, drl431 and Caoimhín like this.
  18. Deepakdkp
    Deepakdkp , via OnePlus 6 , Aug 6, 2020 :
    Checked that, stuck on May update.
    Will check Google forum.
    rhyd1am likes this.
  19. rhyd1am
    There's no telling with Google. Seems completely random 🤷‍♂️
