321
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. G1565800377798
    Cupcake Aug 6, 2020
  2. G_Jugal_Naik_lGUS
    Cupcake Aug 6, 2020
    G_Jugal_Naik_lGUS , via OnePlus 6T , Aug 6, 2020 :
    6t launched with Android 9
  3. Hima_Sumanth
    Cupcake Aug 6, 2020
    rhyd1am likes this.
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 6, 2020
    Caomhin , via OnePlus 6T , Aug 6, 2020 :
    When OnePlus decide, send a feedback form to the developers, more the merrier
  5. amanps
    Gingerbread Aug 6, 2020
    amanps , via OnePlus 6 , Aug 6, 2020 :
    New feature is ready and i think that oneplus 6 series should also support it and if not please start a poll for the requesting this feature and other features too. Hope oxygen 11 also hit oneplus 6 series
    rHITkM likes this.
  6. Caomhin
    rHITkM, ItsRavi25 and drl431 like this.
  7. Caomhin
    rHITkM, ItsRavi25 and rhyd1am like this.
  8. Caomhin
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Once done, use the phone for a couple of days without adding apps to check for issues with just the raw fresh OOS only.
    Only introduce previous 3rd party apps gradually over 2 weeks to see if any particular app or apps drain the battery
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    rHITkM and drl431 like this.
  9. Caomhin
    6 series launched with Android 8. Nothing to do with T variant, internals are the same, externals may have changed a little.
    But like my 6T. The fundamentals are the same.
  10. Caomhin
    amanps
    Here ya go, good luck with this.
    Submit your suggestion to the Ideas platform or to the Feedback section. This will go direct to OnePlus developers.
    Ideas
    https://www.oneplus.com/communityideas#/
    Feedback tool
  11. zeb_bwp
    Froyo Aug 6, 2020
  12. ro.gan_india
    Cupcake Aug 6, 2020
    ro.gan_india , via OnePlus 6 , Aug 6, 2020 :
    hi. when will 10.3.5 update be sent to OP6 , for India or everyone ? it would be a great help if anyone could tell by when it would be released as im facing non customization problems with oneplus buds. thanks
  13. Vivek_Kumar...
    Donut Aug 6, 2020
  14. rhyd1am
    KitKat Community Expert Aug 6, 2020
    rhyd1am , Aug 6, 2020 :
    You can either wait for the OTA for 10.3.5 (which includes security patch). Or you can download the update and install it manually via local upgrade.
    Incremental update OnePlus 6
    https://otafsg1.h2os.com/patch/amaz...gen_22_OTA_046-047_patch_2007191515_f9bd1.zip
    Full update Oneplus 6
    https://otafsg1.h2os.com/patch/amaz...Oxygen_22_OTA_047_all_2007191515_d9e52461.zip
    Incremental update Oneplus 6T
    https://otafsg1.h2os.com/patch/amaz..._046-047_patch_2007171912_5566e9d41cbb5d6.zip
    Full update Oneplus 6T
    https://otafsg1.h2os.com/patch/amaz...TOxygen_34_OTA_047_all_2007171912_ac6dc9b.zip
    To install it via local upgrade, download the correct file for your device.
    Check that the file is placed in your root directory by opening file manager>click on storage>click on internal storage (this is your root directory).
    If the file ends in .jar then delete the. Jar so that the file ends in .zip.
    Then go to settings>system>system updates>click the cog in the top right corner>local upgrade>select the file you downloaded.
    Or alternatively you can download the 3rd party "Oxygen Updater" ago from the playstore.
    rHITkM, ItsRavi25, drl431 and 2 others like this.
  15. Maxj550
    Eclair Aug 6, 2020
    Maxj550 , via OnePlus 6 , Aug 6, 2020 :
    I have the 10.3.5 update downloaded to my OnePlus 6. Not going to update... yet.. will watch the threads to see if issues have been resolved by users [e]1f60a[/e]
  16. Caomhin
    rHITkM likes this.
  17. Caomhin
    Mine runs like a clock on 10.3.5, but then again it has always done that. Happy days 😎[e]1f44d[/e]
    rHITkM, ItsRavi25 and Maxj550 like this.
  18. zeb_bwp
    Froyo Aug 6, 2020
    zeb_bwp , Aug 6, 2020 :
    Found nothing. I have OnePlus Community Version 2.5.0
  19. scorpidi22
    Donut Aug 6, 2020
