320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. Flewoutcuckoonut
    Gingerbread Jul 31, 2020
  2. rhyd1am
    KitKat Jul 31, 2020
    rhyd1am , via OnePlus 6T , Jul 31, 2020 :
    DroidOnePlus
    Those apps give developer option's force dark mode & it is very unstable. Try suggesting better option​
    Not at all like force dark I've been using tiles since android 9 (not for the dark toggle back then obviously). I have kept it since then just for the dark toggle alone. It literally only turns on dark mode or turns it off (just as if you turn it on in customisation settings).
    I was only suggesting AN option available to you that had worked perfectly for me on android 10 🤷‍♂️
    https://play.google.com/store/apps/details?id=com.rascarlo.quick.settings.tiles
    Chosen_One, drl431 and Caoimhín like this.
  3. Tony A
    Eclair Jul 31, 2020
    Tony A , Jul 31, 2020 :
    The optimized RAM management made my OP6 a little snappier! Thanks OnePlus!
  4. Kubo_S
    Froyo Jul 31, 2020
    Kubo_S , Jul 31, 2020 :
    this device is not officialy supported longer
  5. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 31, 2020
    Caomhin , via OnePlus 6T , Jul 31, 2020 :
    Well this update is for 6 series, am sure there will be other updates for other Phone series in the near future.
    Whining on here to 6 series users is a bit pointless, as OnePlus do not monitor these threads.
    Contact OnePlus directly to air your grievances.
    Submit your suggestions to the Ideas platform or to the Feedback section. This will go direct to OnePlus developers.
    Ideas
    https://www.oneplus.com/communityideas#/
    Feedback tool
    Chosen_One, ItsRavi25 and drl431 like this.
  6. suresh4frens
    Donut Jul 31, 2020
    suresh4frens , Jul 31, 2020 :
    its a joke.
  7. The1Lion
    Marshmallow Jul 31, 2020
  8. g_castorina
    Froyo Jul 31, 2020
  9. ARX007
    Froyo Jul 31, 2020
    ARX007 , Jul 31, 2020 :
    what about the lag issue with the bullets wireless z even in fnatic mode?!...damn I wish I hadn't bought it :(
    Mridul.S likes this.
  10. Seshananda Reddy M
    Cupcake Jul 31, 2020
  11. Ashik666
    Donut Jul 31, 2020
  12. ankampra
    Donut Jul 31, 2020
  13. TheAmirSheikh
    Eclair Jul 31, 2020
    Srínívas Sñ likes this.
  14. rHITkM.
    Honeycomb Jul 31, 2020
    rHITkM. , Jul 31, 2020 :
    have you read the product information before purchase
    ARX007 and Caoimhín like this.
  15. 2602ashvin
  16. Srínívas Sñ
  17. Caomhin
  18. adi1001
    adi1001 , via OnePlus 6T , Jul 31, 2020 :
    Add one more .
    - optimised charging
    vishrutkmr7 and rHITkM like this.
  19. Caomhin
    1, 2, 3 are not missing, they are not included. To be missing they would have to be there in the fist place.
    4. Battery issues try the following.
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Once done, use the phone for a couple of days without adding apps to check for issues with just the raw fresh OOS only.
    Only introduce previous 3rd party apps gradually over 2 weeks to see if any particular app or apps drain the battery
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    OP6T Battery and Heating Thread
    https://forums.oneplus.com/threads/unified-op6t-battery-and-heating-thread.952987/
    Chosen_One, Tommy11, inkaine and 2 others like this.
