321
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. G_Tejas_More_jIIm
    Cupcake Aug 6, 2020
  2. Caomhin
    9 Series Expert, Participator of the Year Community Expert Aug 6, 2020
    rHITkM, ItsRavi25 and drl431 like this.
  3. Caomhin
    Caomhin , via OnePlus 6T , Aug 6, 2020 :
    Excellent question, they seem to be peeved, OP6 is a higher build release number.
    rHITkM, drl431 and ironass like this.
  4. zeb_bwp
    Froyo Aug 6, 2020
    zeb_bwp , Aug 6, 2020 :
    I have System Customization Preset set at Vibrant Tint and Tone at Dark but Community App still doesn't follow it. Thanks for info though.
  5. rhyd1am
    KitKat Community Expert Aug 6, 2020
    rhyd1am , via OnePlus 6T , Aug 6, 2020 :
    I've just changed my theme to exactly the same as you stated, and the app has remained dark.
    I can only assume that it's because of the version of the app you're using. I've always used the beta version of the community app.
    Version 3.4.0.0.200715165156.0032589
    rHITkM and Caoimhín like this.
  6. cmontero78
    Donut Aug 6, 2020
    cmontero78 , via OnePlus 6T , Aug 6, 2020 :
    You have to update it manually from the Play Store. The Community app that comes with the phone doesn't auto update .
    zeb_bwp likes this.
  7. zeb_bwp
    Froyo Aug 6, 2020
    zeb_bwp , via OnePlus 6 , Aug 6, 2020 :
    Yes. This worked. Thanks mate.
    Caoimhín likes this.
  8. 77_dhruv_77
    Donut Aug 6, 2020
  9. James.Mitchell
    Cupcake Aug 6, 2020
  10. Caomhin
    As per first post top of the thread
    If you get an answer to that question, please let the forum know. 10.3.6, 10.3.7 and 13 more before then. You will probably have Android 11 before that. Next year sometime.
  11. U1551898310567
    Cupcake Aug 6, 2020
  12. rhyd1am
    It's a staged, random rollout. It goes first to a smaller group of "random" users, before going out to increasingly larger groups of users, and can take a couple of weeks to reach everyone.
    It's done this way to try to minimise the chance of any major bugs getting out there. Be patient and it'll soon reach your device 🙂
    rHITkM, Caoimhín and drl431 like this.
  13. G_jeffy_john_ZjJp
    Cupcake Aug 7, 2020
    G_jeffy_john_ZjJp , Aug 7, 2020 :
    I have a problem with my OnePlus 6 can u help me my WiFi is not connecting I have to reboot or clear my settings data then it works but if I turn off my WiFi (phone) it doesn't reconnect with the WiFi and I have to reboot or clear my data again can you help me
  14. K1ngst0n1
    Cupcake Aug 7, 2020
    K1ngst0n1 , via OnePlus 6T , Aug 7, 2020 :
    Hello, I'm using Oneplus 6T and formally it was connecting to my LG smart TV, after upgrading it to OxygenOS 10.3.5, it can connect all right but can't cast onto the tv screen. What should I do pls?
  15. Snjvworrior
    Eclair Aug 7, 2020
    Snjvworrior , via OnePlus 6T , Aug 7, 2020 :
    I thought this update was awesome but now I m facing issues like battery drain, battery temp increased by 5% at the minimum which used to be 24 but now it's 29 as I live in cold region. Screen on time at average is 5 and half hours which used to be 7 hours. No issue with wifi but their is some screen flickering issue while forwarding videos in youtube...damn these updates it's getting worse after every updates...I wonder if the company is reliable anymore... I better switch back to android 9 as it was the best terms of battery wifi connectivity and screen calibration mode..
    RajulaRreddy likes this.
  16. Snjvworrior
    Eclair Aug 7, 2020
  17. drl431
    Junior Moderator, Community Hero 2020 Junior Moderator Aug 7, 2020
    drl431 , Aug 7, 2020 :
    I haven't noticed any difference casting Facebook live videos with this update. Is there a specific app or content that you can not cast?
  18. tarunkumar499499
    Cupcake Aug 7, 2020
    Reetej Kumar khadka likes this.
  19. drl431
    Just like previous updates, this is a staged random roll-out, as stated in the first post in this tread.
  20. Snjvworrior
    Eclair Aug 7, 2020
    Snjvworrior , Aug 7, 2020 :
    jus downgraded from 10.3.5 to 9.0.4 and I will not update till I receive android 11...
