320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. et121677
    Froyo Aug 8, 2020
    et121677 , via OnePlus 6 , Aug 8, 2020 :
    ItsRavi25
    I don't play games that's the reason i am getting good SOT. And my every app on optimize.​
    I don't game either... I'm still happy with my battery life but more SOT is always better. I wonder if anyone else is getting over 10+ hours. maybe some of my apps are draining the battery. I'll have to monitor more closely
  2. rhyd1am
    KitKat Aug 8, 2020
    rhyd1am , via OnePlus 6T , Aug 8, 2020 :
    I know a couple of users on here who get those kinds of screen on times. I don't get near the 10hr mark myself, but I've never had a single day since the release of the 6T where I've been concerned that I might run out of battery. Almost aways get around 5-6 hours.
    et121677, Auristic and Caoimhín like this.
  3. YWESH
    Cupcake Aug 9, 2020
  4. Navalture
    Eclair Aug 9, 2020
    Navalture , via OnePlus 6 , Aug 9, 2020 :
    Can you please share your screen shot of getting 10 to 11hrs of SOT
  5. Badri@pavan
    Donut Aug 9, 2020
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 9, 2020
    drl431, Auristic, rhyd1am and 2 others like this.
  7. Caomhin
    Caomhin , via OnePlus 6T , Aug 9, 2020 :
    Clear Playstore App info Cache and App info Storage as well, see if that helps
  8. Caomhin
    drl431, Auristic and ItsRavi25 like this.
  9. YWESH
    Cupcake Aug 9, 2020
    YWESH , via OnePlus 6 , Aug 9, 2020 :
    It will not open still, my games seem to be affected as well, they will not open either. If a game does open I cannot interact with it.
  10. Caomhin
    That should never happen, sounds like a major glitch.
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Once done, use the phone for a couple of days without adding apps to check for issues with just the raw fresh OOS only.
    Only introduce previous 3rd party apps gradually over 2 weeks to see if any particular app or apps drain the battery
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
  11. Caomhin
    Not gonna happen on a 2 year old design. However, if you give feedback and ideas slim possibility.
    Submit your suggestion to the Ideas platform or to the Feedback section. This will go direct to OnePlus developers.
    Ideas
    https://www.oneplus.com/communityideas#/
    Feedback tool
  12. Caomhin
    Either try the second part first, or try all the steps.
    Go to Settings,
    System,
    Reset Options,
    And here
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    OP6T Battery and Heating Thread
    https://forums.oneplus.com/threads/unified-op6t-battery-and-heating-thread.952987/
  13. Caomhin
    Reset your Mobile Network adapter
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    See if that helps.
  14. ZATINRANA
    Cupcake Aug 9, 2020
  15. D.Sai Suhail Baba
    Jelly Bean Aug 9, 2020
    D.Sai Suhail Baba , Aug 9, 2020 :
    Just change options from Intelligent control to Optimise for less using apps. And for regular using apps you can have system default option Intelligent control. It helped me a lot. SOT of 10+ hour's and charging my device once in a day.Mostly I changed all apps to optimise except apps like YouTube, WhatsApp , Gmail as these are used daily they're under intelligent control option. I hope my suggestion will help you.
    et121677, rhyd1am and Caoimhín like this.
  16. D.Sai Suhail Baba
    Just change options from Intelligent control to Optimise for less using apps. And for regular using apps you can have system default option Intelligent control. It helped me a lot. SOT of 10+ hour's and charging my device once in a day.Mostly I changed all apps to optimise except apps like YouTube, WhatsApp , Gmail as these are used daily they're under intelligent control option. I hope my suggestion will help you. After changing settings please restart your device.
    ZATINRANA and Caoimhín like this.
  17. Caomhin
    If that doesn't fix it, then. I would suggest, backup your phone and then do a complete Erase All Data factory reset. Had the issue myself quite a while back, issue of my own making, I might add. But the reset ended up being the only way to rectify it. See above on how to do that.
    drl431, Auristic, rhyd1am and 4 others like this.
  18. alshahriyar , via OnePlus 6 Silk White , Aug 9, 2020 :
    Just go to OnePlus website you'll find the new firmware there download it copy it to your phones main file or in the root directory then update by locally
  19. Caomhin
    alshahriyar
    Just go to OnePlus website you'll find the new firmware there download it copy it to your phones main file or in the root directory then update by locally​
    Just to be aware, the current version posted there is 10.3.3, people will then have to OTA or use files posted in this thread to update to 10.3.5.
    So if they are on anything from 10.3.3 or above, it's pointless going to the website.
    And they need to be on a certain version of 9 before upgrading to 10.
    But if on a Beta10 version, they should be fine.
    https://www.oneplus.com/support/softwareupgrade
    Just to be aware is all.
  20. Ajayjoelabraham
    Froyo Aug 9, 2020
