The new update is the most stable update of Android 10.
For battery draining issue try this.
You can calibrate to enhance your battery life
For battery draining you should follow this to calibrate..
Goto settings >App and notifications>Click on three dot in right corner>Reset app preference.
To Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
Thanks to
@Caomhin 😇...
And for Fingerprint issue.
Remove all the fingerprint and reinstall the new fingerprint.
