320
OxygenOS 10.3.5 for the OnePlus 6 and 6T
  1. H1575034669071
    Cupcake Aug 9, 2020
    H1575034669071 , Aug 9, 2020 :
    I can't access setting because phone don't start without graphical password. Entering the password fails at the stage of loading the phone
  2. adi1001 , via OnePlus 6T Midnight Black , Aug 9, 2020 :
    Ok bt should we charge device keeping turned on or off ?
    Caoimhín likes this.
  3. ItsRavi25
    Jelly Bean Aug 9, 2020
    drl431, Caoimhín and adi1001 like this.
  4. adi1001 , via OnePlus 6T Midnight Black , Aug 9, 2020 :
  5. Caoimhín and ItsRavi25 like this.
  6. Caoimhín
    OnePlus 9 Series Expert Community Expert Aug 9, 2020
    Caoimhín , via OnePlus 6T , Aug 9, 2020 :
    I leave my phone turned on. I usually reboot it every couple of days. Just out of habit. Done it with all the phones over the years.
    drl431, adi1001 and Auristic like this.
  7. Caoimhín
    By default your phone is encrypted with security, if you are entering the incorrect password, you will not be able to access the phone.
    That's why there is a password, to ensure your phone is secure.
    You will have to wipe your phone and reset it, and lose all data to get it back up and running.
  8. Auristic
    Lollipop Aug 9, 2020
    Auristic , Aug 9, 2020 :
    Choose "Use device MAC address" instead of "Use random MAC address" in WIFI settings.
    drl431, rhyd1am and Caoimhín like this.
  9. Caoimhín likes this.
  10. AbdulKarim99
    Cupcake Aug 9, 2020
  11. Caoimhín
    As has been explained here over the last couple of days in other posts, probably when Android 11 appears for 6 series next year.
    Auristic, kjjm, ItsRavi25 and 2 others like this.
  12. D.Sai Suhail Baba
    D.Sai Suhail Baba , Aug 9, 2020 :
    If you want to know about AOD then wait for tomorrow's OnePlus Android 11 final preview release. They may inform which devices are supported for AOD , if supported how many AOD themes will released to devices(older device).
  13. ra2525
    Cupcake Aug 9, 2020
  14. Caoimhín
    Update your OnePlus Launcher from the Playstore and clear the OnePlus Launcher App info Cache as well after installing, see if that helps.
    Auristic, zayn_ys and rhyd1am like this.
  15. rhyd1am , via OnePlus Community App , Aug 9, 2020 :
    For gallery and file manager you can try this from @B_Wrath post on the 10.3.3 thread
    Q: I am not able to access the storage, Google play crashes, gallery is empty.
    A: This happens when you move from Beta 6 to stable 10.3.3 directly without using the rollback.
    Delete the data and cache of downloads app and download manager. This should fix the problem.
    Thanks to @NodePoint for finding the solution.
    I can't understand for the love of God, why few so called "competent beta testers" can't even access few apps!
    Q: How to access the downloads and download manager app?
    A:
    Step 1: Unlock your phone.
    Step 2: Open app drawer and locate settings app / bring down the QS panel and click on the gear icon.
    Step 3: Click on the search tab on top of the settings app.
    Step 4: Type "downloads" and then click on the app. Clear it's cache and storage which is under the storage tab.
    Step 5: Type "download manager" and then click on the app. Clear it's cache and storage which is under the storage tab.
  16. Prafull@16
    Donut Aug 9, 2020
  17. rhyd1am
    KitKat Aug 9, 2020
    drl431, Auristic, ironass and 2 others like this.
  18. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Aug 9, 2020 :
    If your system theme is dark then your community will automatically dark (it follows system theme)
    For dark mode
    Settings > Customization > Preset theme > Nuanced Dark.
  19. Prafull@16
    Donut Aug 9, 2020
    Prafull@16 , via OnePlus 6 , Aug 9, 2020 :
    I got the dark mode after reinstalling the app
    R1596958844896 likes this.
  20. R1596958844896
    Cupcake Aug 9, 2020
