112
OxygenOS 10.3.6 for the OnePlus 6 and 6T
  1. jrsamp
    Gingerbread Oct 13, 2020
    jrsamp , Oct 13, 2020 :
    It's fantastic!! This whole crowd first call for security patch, when the patch arrives they all call for Android 11, if Oneplus now launched Android 11 they would definitely want a new phone!
    If I were Carl Pei, I would certainly run away ... :rolleyes::D:cool:
    iamrj, kjjm, Auristic and 3 others like this.
  2. T1539496809178
    T1539496809178 , Oct 13, 2020 :
    OnePlus is all about tech-savvy, if you guys can't flash roms, root, restore their devices to their prime ... You're in a wrong territory, yes they're few bugs and they will be there for another 100 years ... Instead of crying you should have gone and try what's working with you
    We're not just fan boys, we're the force that reckons the effort behind an ecosystem where smartphone giants are listening to their loyal customer base.
    Apple systematically downgrades their earlier flagships.
    Samsung with its UI and Exynos chipset.
    Xiaomi with their OS experience.
    See every single company is plagued with problems and its your choice to stay with whatever you wish to.[/QUOTE]So you are the force that is not letting them know about the small bugs?? gr8 work tech savvy guys[e]1f525[/e][e]1f525[/e] Hard Resetting and flashing rom made a guy tech savvy never knew that..That means i have been that kind of tech savvy since a long time [e]1f602[/e][e]1f602[/e]
    Certainly a force to reckon with ....FanBoyForce
    Now in order to use a phone without bugs you ought to be tech savvy ....its not the responsibility of the company developers to correct that bug....just keep hard resetting your phone [e]1f602[/e][e]1f602[/e] Nice work dude
    drl431, Auristic and mr_scott like this.
  3. D.Sai Suhail Baba
    Ice Cream Sandwich Oct 13, 2020
    D.Sai Suhail Baba , Oct 13, 2020 :
    He did same left company to start his own venture.
    iamrj, Auristic and Caomhin like this.
  4. Lelander2015
  5. YourAvgOnePlusUser
    Eclair Oct 13, 2020
    YourAvgOnePlusUser , via OnePlus 6 , Oct 13, 2020 :
    Well, this happened before the 24 months, so stop defending something they did wrong. And so what if it's a 2yr old device? My midrange Huawei received one update every 3 months, but at least it was the latest.
  6. Lelander2015
    Lelander2015 , via OnePlus 6 , Oct 13, 2020 :
    59 percent charge at 19 hours. 1 day 2 hours left. 2 hours 10 min sot. I was getting 30 hours total on last update.
  7. mischa1981
    mischa1981 , Oct 13, 2020 :
    Well, I know why I’ve changed to iPhone. At least 5 or more years of support. Don’t care about apps outside of the App Store. I never installed APKs from mirror sites or apps that will never get in the Play store.
    It was a nice time with Oneplus but I am a happy iPhone user now.
    D.Sai Suhail Baba likes this.
  8. CHANCHALSINHA
    Cupcake Oct 13, 2020
  9. Caomhin
    Marshmallow Oct 13, 2020
    Caomhin , via OnePlus 6T , Oct 13, 2020 :
    Good for you. Next !!!!
    ItsRavi25 likes this.
  10. D.Sai Suhail Baba
  11. Sacca96
    Eclair Oct 13, 2020
  12. R1529828367798
    Eclair Oct 13, 2020
    R1529828367798 , Oct 13, 2020 :
    i have been having an issue where the camera app on being launched is unresponsive for well over 3 seconds and also lags the whole system out
  13. Caomhin
  14. Caomhin
    Clear the OnePlus Camera App info Cache and App info Storage as well.
    See if that helps
    ItsRavi25 and Auristic like this.
  15. nguyenphong108
  16. R1529828367798
    Eclair Oct 13, 2020
    it does but for a week at max then it starts lagging again
  17. Caomhin
    Clear the Google Play Services App info Cache and App info Storage as well.
    Also clear the Google Play Services App info Cache and App info Storage as well.
    Then restart the phone
    You may have to give it a full charge cycle to see any benefit.
    Also try the following.
    Try to Optimize the phone, this helps with Lag, Heat, Battery Drain and much more.
    Clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Guide to lower Battery Drain.
    drl431, ItsRavi25 and Auristic like this.
  18. D.Sai Suhail Baba
    Caomhin likes this.
  19. Royal_RJ
    Honeycomb Oct 13, 2020
