165
OxygenOS 10.3.7 for the OnePlus 6 and 6T
  1. ManikSharma98144
    Donut Nov 25, 2020
    ManikSharma98144 , via OnePlus 6T , Nov 25, 2020 :
    Go to Apps & Notifications and from there , go to OnePlus Membership. Click on app installed from play store. It'll redirect you to play store. From there uninstall the Red Cable Club app. It'll solve the issue.
    #41
    BhattHarsh97 and Rajesh Gokhale like this.
  2. OnePlus.rksharma
    Honeycomb Nov 25, 2020
    OnePlus.rksharma , via OnePlus 6T , Nov 25, 2020 :
    It's working... Thanks buddy 👍👍
    #42
    ManikSharma98144 likes this.
  3. P1606128078800
    Cupcake Nov 25, 2020
    #43
    Reetej Kumar khadka likes this.
  4. mika90
    Froyo Nov 25, 2020
    mika90 , Nov 25, 2020 :
    hi, with this version vowifi doesn't work anymore [e]1f621[/e][e]1f621[/e][e]1f621[/e]
    #44
    F1554616976196 likes this.
  5. maximus2708
    Froyo Nov 25, 2020
    #45
    P1606128078800 likes this.
  6. P1606128078800
    P1606128078800 , Nov 25, 2020 :
    how to do that sir ? , Help
    #46
  7. maximus2708
    Froyo Nov 25, 2020
    #47
  8. rhyd1am
    KitKat Nov 25, 2020
    rhyd1am , Nov 25, 2020 :
    First you'll need to update it to version 9.0.9 if you have a OP6 or 9.0.17 if you have a OP6T (this is required for preparation for Android 10). You can download it from here
    https://oneplusupdates.com/
    After downloading the file, you'll need to move it to root directory. To do this, open file manager and click on downloads. Long press on the downloaded file and then press the 3 dot menu in the top right corner. Select "copy"and then click on "internal storage", followed by "paste"
    After moving the file to your root directory, go to settings>system>system updates>hit the cog in the top right corner>local upgrade and select the file
    After 9.0.9/9.0.17 has been installed, go to the Oneplus support page http://www.oneplus.com/support and download the latest available android 10 build for the 6t. Install this in the same way as before.
    You should then be in a position to receive 10.3.7 via an OTA update.
    #48
    Mridul.S, ItsRavi25, Auristic and 2 others like this.
  9. P1606128078800
    #49
  10. ironass
    Lollipop Nov 25, 2020
    ironass , Nov 25, 2020 :
    Already described that in your other post, here
    #50
  11. P1606128078800
    #51
  12. maximus2708
    Froyo Nov 25, 2020
    maximus2708 , Nov 25, 2020 :
    why should he download the file from the official site. if he updates to 9.0.17, and receives OTA 10.3.6
    #52
    D.Sai Suhail Baba and Duvel999 like this.
  13. rhyd1am
    KitKat Nov 25, 2020
    rhyd1am , via OnePlus Community App , Nov 25, 2020 :
    I have posted one of the many pre prepared responses that I have saved. I realise that he would indeed receive 10.3.6 via OTA, but I simply do not have the time to edit every single response I make.
    The content of my post is still factually correct, regardless of he updates to 10.3.6 via OTA or if he does it manually 🤷‍♂️
    #53
  14. Caomhin
    Community Hero 2020 Nov 25, 2020
    Caomhin , via OnePlus 6T , Nov 25, 2020 :
    If you are OnePlus 6T you need to download and install OOS 9.0.17 as this contains files to allow you to update to Android 10.
    Download 9.0.17 for OnePlus 6T from link below.
    https://oneplusupdates.com/device/oneplus-6t
    After the .zip file is downloaded to your phone, move the file from the folder you downloaded to, to your Main Storage.
    Then go to 'Settings' - 'system update', click the 'settings' icon on the top right corner, choose 'Local upgrade', find the .zip file and click on 'Install' to confirm.The update takes about a minute (depending upon the file size), once done reboot your device to boot into the latest Oxygen OS.
    ⚠️Make sure you download the correct file for the model of phone you have. ⚠️
    Then choose your model of phone in the list in the link below and download and install the Android 10.3.5 file, follow the instructions given on the OnePlus Software Support page, link below.
    https://www.oneplus.com/support/softwareupgrade
    #54
  15. Kuronosu
    Froyo Nov 25, 2020
    #55
  16. Caomhin
    Quick review. Started the day with 100% after overnight charge. Just for reference had 69% Battery when downloading and installing 10.3.7 earlier today.
    After installation reboot, had 67%, from there to now still have 33% left. And this is my SOT for today, after running the phone before and after installation. So far it's going excellent on my 6GB 6T
    And my current battery health is 81%
    #56
    Gramisan, iamrj, dashxdot and 3 others like this.
  17. Tedinetto
    Gingerbread Nov 25, 2020
    #57
  18. dhairyarc1
    Ice Cream Sandwich Nov 25, 2020
    #58
  19. Meet_GrimReaper
    Froyo Nov 25, 2020
    #59
  20. rhyd1am
    KitKat Nov 25, 2020
    #60
    Caomhin likes this.
